| Registered |
				930 with SC cam ??
			What type of gains can you get from changing stock 930 3.3 L cam profile with an SC grind camshaft ??? Keeping in mind that my other mods are only a K-27 and a single outlet PowerHaus muffler and stock exchangers. The car is Canadian (ROW = 300 HP stock) Thanks Jerry S | ||
|  02-18-2005, 02:07 PM |
| Registered Join Date: Mar 2001 Location: Marysville Wa.
			better low end response.   like now, when you take off from a stop, or try to accelerate from 30mph in 2nd, there ain't a whole lot of pickup for a while.
				__________________ https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 | ||
|  02-18-2005, 02:10 PM |
| Registered |
			what type of cam would be the best match for a K-27 1100. is there a horsepower number that could be associated with the SC ??? | ||
|  02-18-2005, 02:16 PM |
| Crotchety Old Bastard |
			I have SC cams in my engine.  Difference is dramatic.  The turbo 3.3L lays down MORE torque now than the modded 3.0L SC engine it replaced.  Maked for excellent driveability.  Torque is good. A 930 engine with K27, SC cams, aftermarket or Euro exhaust, and larger intercooler should put down HP numbers close to 400. A search on the topic should verify that number. The formula is tried and true.
				__________________ RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 | ||
|  02-18-2005, 05:35 PM |
| Registered |
			Would an improvement be found using SC cams in a 92` 3.3 turbo ? I guess you would call them 965 cams .  Kurt Williams
				__________________ Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd | ||
|  02-18-2005, 05:41 PM |
| Registered |
			Are you sure your tools fit post 73 Porsches, Kurt?  I know you have some modern wrenches for the Z, but it seems kind of out of your character to work on Porsches with rubber bumpers   Or are you refering to the 69' with the retrofitted engine?
				__________________ Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT | ||
|  02-18-2005, 07:53 PM |
| Registered |
			what would the best cam be to put in for the most power assuming an otherwise stock configuration ? And is it still relatively still street driveable? Thanks Jerry S | ||
|  02-20-2005, 03:19 PM |
| Registered | Quote:
 Yes you are correct . Its a 69` with the c2 turbo engine . Good eye. Kurt Williams
|  02-20-2005, 03:39 PM |
