3 restos WIP = psycho
More (longhood) pedal cluster questions
With the recent woes I had had with my throttle, I have come across several other questions and issues with my pedal cluster. First thing I noticed is that my clutch pedal is a little sloppy on the release, but then I noticed this:
It looks like a boss with a detent for a spring, with a matching one at the back of the pedal cluster. Am I missing some sort of clutch pedal return spring on my car? The next issue has to do with the brake light microswitch. Is this what it is supposed to look like? My washer that the switch actuates off of is pretty ghetto at this point. Is it supposed to be so flimsy? Is there an easy way to replace it? Thanks again.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
don't know about the brake light i have a RHD car and the set up is a little different. But you sure are missing your clutch return spring it's a real PITA to replace.
Watch out for your fingers.. Ask me how i know
Classic 1969 911T |
This pic may help.
Steve B. 1971 T 2.2 w/Zeniths Gruppe B member 171 Mid 9 Web Site Guy |
Double Trouble
Nice job Steve!
I used to be addicted to the hokey pokey..........but I turned myself around.. 75 914 1.8 2010 Cayenne base |
I would rather be driving
Interesting, neither of my 71 cars have a clutch return spring. They do not even have the extension on the clutch cable arm to hold one. I have never noticed any sluggishness in return.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
None of those photos show a '71 cluster. The correct cluster has a different design clutch pedal and no spring.
Steve, thanks for the pic!
I do notice that your throttle arm is significantly bent outward. This can come from a misadjusted throttle stop on the floorboard, which puts torque stress on the arm. If it bends enough, the throttle arm can stick under the firewall when you try to decelerate, resulting in a stuck pedal at WOT. Ask me how I know... That's the reason I am here today.
My '71 has the return spring. The pedal box is original, I'm quite sure. Just rebuilt it a few weeks ago. It is a B*tch to replace in the car. If you are rebuilding, may as well install the spring out of the car. My washer is just as flimsy. You easily buy another washer from the hardware store. It is about 10mm ID.
1971 RSR - interpretation |
Sorry--let me clarify: the early -73 cluster has the clutch return spring on the right side. The 74- cluster has the clutch return spring on the pedal arm itself.
Again: if you have a 2-piece clutch pedal arm, it's an early cluster. If you have a 1-piece clutch pedal arm (as shown above) it's a 74- cluster. Here's a pic of the -73 cluster from the Pelican tech article: Last edited by RallyJon; 07-18-2005 at 07:54 AM.. |
Where did you get that diagram? Is that what the PET looked like before they digitized it or is it from something else?
Is it possible you have a late clutch pedal arm on an early shaft (with the spring on the right side and the "bent" lever on the right)? Since it's pretty likely that a 30+ year old pedal cluster's been rebuilt, you may have mix-and-match parts. I have a weird hybrid myself, using early cluster with a later shaft. Rebuilding it correctly is a future project...
Possible. If my memory serves me correctly, though, there is a boss for the clutch return spring on the cluster base, correct? My base does indeed have the boss. After looking at the PET for a '77, it appears likely I have a later unit.
'69: '77:
The pic I posted isn't from my car but shows the newer style pretty well. My 71 has the early style without the big spring on the left. I have a pedal set from a 76(?) that looks like the one in the photo. The spring was missing on that pedal set, but it was from a scrap yard, so it may have been taken.
OK, so if I have the later cluster, how do I know which one? Apparently there are different springs for '74-'76:
and for '77-'89: What is the differnce other than the price? Clutch Pedal Return Spring, 911 (1974-76) C-423-305-05 $20.70 Clutch Pedal Spring, 911 (1977-89) C-423-305-06 $7.80
The only difference looks like the finish; I took a chance and ordered the later (cheaper) one from Pelican today.
Sorry to barge in on the thread but I had a pedal cluster question that is relevant to this discussion.
My accelerator pedal/throttle sticks about 1/4 down so I was about to take it apart and replace the bushings and give it a solid lube job. After removing the floorboard and cleaning out the debris behind it, I found the piece circled in the pic on the floor: My brakes and clutch work fine (I prefer not to mess with 'em) as do the brake lights. Any idea as to what is that piece and what does it do?
1972 911T targa |
that is only a pedal return stop. There is a small rubber section that prevents them from going clunk on return. The stop is bolted to the side of the pedal cluster base and acts as a guide tube for the clutch pedal arm to ride through and the brake pedal arm to ride on. I don't see how it could be laying on the floor unless you had pedal cluster failure.
Pretty sure it's just a rubber stop (pad) for the return of the pedal so it doesn't hit metal on metal.
(edit) looks like Jamie and I answered at the same time.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 Last edited by kenikh; 07-19-2005 at 01:53 PM.. |
