Where can I find these ignition wire holders?
I've seen them on the Ruf CTR:
They're the ones that are mounted along the top of the fan. Any ideas? TIA. |
stock 3.2 stuff. be aware that the wires that they hold have a rubber sheath that makes the wires bigger. regular wires would be loose .
Thanks John. That is good as the magnacore wires are 8.5 mm and will be just about right. I have a 85 motor here that has a differant set up that is also factory. I'll try to attach the photo.
