Thumbs up Guess what I have.....Hint: 3 Watt instrument bulbs.
Finally in from Germany. My next door neighbor's nephew is a car nut/engineer over in Germany (the Eifel (near the Nürburgring)). He was able to source the elusive BA7s based 3W/12V bulbs.
This weekend I'll start to conduct some simple tests to present to the crowd.
The following tests will be conducted for new Bosch 2W bulbs, new 3W bulbs and my 20 year old OE bulbs :
- Individual current draw
- Light meter readings (In and/or out of guage??)
- Visual impressions/pics
I'm trying to decide on an appropriate power source for the test as I'd like to conduct indoors. I'll also have to source a light meter...I think dad has an old german one .
From there we can attempt to calculate load capabilities of the dash harness.
Cross your fingers.
Warren & Ron, may you rest in Peace.
Old 03-08-2005, 01:36 PM
Rick Lee's Avatar
I want a set!
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 03-08-2005, 01:39 PM
304065's Avatar
Rick,
No matter what, the factory's dash harness is pretty weak. It's a finer gauge, like 18 or so, and there's no fuse. Any retrofit solution should go to a lower gauge wire with better power handling capability and a fuse for safety.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 03-08-2005, 01:53 PM
Originally posted by john_cramer
Rick,
Agreed. Don't want to present a possible "solution" that introduces a fire risk. Let's get some values together and see what we have. Should at least be interesting.
While we're at it I'm hoping the bulb socket is capable of the increased draw.
Old 03-08-2005, 01:58 PM
rfuerst911sc's Avatar
I am interested in the results please keep us up to date.
Old 03-08-2005, 02:04 PM
me four. i'll deal with the wire size, regardless.
206 637 4071
Old 03-08-2005, 02:36 PM
Driving member
jester911's Avatar
Yep,
I would love to be in if it works.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 03-08-2005, 02:43 PM
steve911's Avatar
Count me in too.
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 03-08-2005, 02:45 PM
Early_S_Man's Avatar
Porsche Crest
RickM,
The instrument illumination bulb Black/Blue wiring is 0.5 mm^2, or slightly smaller than 20 ga on the AWG chart ... as shown below:
My suggestion for bench testing is to use a variable 0 - 20 Volt power supply, monitored by a good digital multimeter, and set the variable supply to the same as your system Voltage -- measured above 2000 rpm with the headlights on ... which tends to run higher [14.5 - 15.0 Volt range] than most earlier cars! You could build a variable power supply with parts from Radio Shack ... a 24 Volt transformer, bridge rectifier, LM317T regulator chip, and a handfull of other parts should fill the bill!
For a light meter ... I would suggest a Gossen Ultra-Pro with Fiber Optic probe.
The bulb sockets won't be a problem, as you are only going from 142 mA at a nominal 14.0 Volts ... to 214 mA. My suggestion for wire size would be 16 ga. There really isn't a fire hazard here with the additional load, but an upgrade should be over-engineered to give the best illumination and reliability. It wouldn't hurt to incorporate a 2.5 or 3.5 Amp circuit breaker into the new wiring loom.
One step in the upgrade should be to clean all of the bulb socket's body with automotive white polshing compound ... to get rid of any oxidation or corrosion, and give the best possible grounding, which does depend on the friction fit in each instrument! You can clean the receptacle for the bulb holders in each instrument by positioning the gauge face up, and apply polishing compound with a Q-tip, scrubbing the sides thoroughly ... followed by isopropyl alcohol on Q-tips as well.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 03-08-2005, 02:46 PM
derek murray's Avatar
I'm in...
'70 911S 1002938
'70 Ducati Mark 3D 350
Old 03-08-2005, 02:47 PM
BOOMER's Avatar
Sweet, I've seen the light........ me too
Old 03-08-2005, 03:49 PM
Re: Guess what I have.....Hint: 3 Watt instrument bulbs.
Bingo
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-08-2005, 04:10 PM
david914's Avatar
I'm in for a set!
BTW, I'd be more concerned about the capabilities of the dash illumination rheostat than the wiring. The stock ~20 AWG wiring will support the additional load, but without knowing the details on the dimmer, I'd proceed with caution. A simple dimmer circuit could be installed to handle the extra load if need be. It could be driven off the stock rheostat.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 03-08-2005, 04:15 PM
buttjoint's Avatar
Where do I sigh up?
scottb's Avatar
I'm in for a set.
1984 Targa
Old 03-08-2005, 04:25 PM
Administrator
Jack Olsen's Avatar
Build a better (or at least, brighter) mousetrap...
I'm in, too.
You should sell a bulb-and-fuse-set combo.
Old 03-08-2005, 04:38 PM
smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
I'm in for a set!
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 03-08-2005, 05:27 PM
Before I opened the thread, my guess was burned-out dash light wiring and curled PC traces
Do you guys really have trouble seeing your dash ?? I usually have my dimmer turned down 1/3 or even 1/2.
Charlie Baer
'79 Euro 911SC (Guards Red)
'83 Quattro (Mars Red)
Old 03-08-2005, 05:35 PM
Shaun @ Tru6's Avatar
I'd love to see my gauges at night. Count me in.
Tru6 Restoration & Design
Old 03-08-2005, 05:53 PM
Definitely interested!
thanks
dave
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 03-08-2005, 06:21 PM
