stv951's Avatar
Does it look too low ???
I know its not a way to tell just by looking, but you have to measure to check, but does it look too low ? I get some rubbing at the front (7x16 with 205s) no problems back with 9x16 and 245s
Old 03-14-2005, 12:46 PM
jyl jyl is online now
jyl's Avatar
Looks nice. As long as the rubbing and driveways are okay, I say you can't be too low. Maybe you can increase front camber to reduce rubbing?
Old 03-14-2005, 12:48 PM
Glasgow 911SC's Avatar
As far as looks go, that's I get rubbing at the front inside. Maybe you should think about fitting a plate similar to Mikes (89911).
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 03-14-2005, 12:51 PM
stv951's Avatar
I am considering dialing more negative camber up front, but was told that I would lose some high speed stability. Car becomes nervous (so they say). Is that true ?
I will also roll the fender lips.
If I increase negative camber I will get more oversteer, right? Car was very nervous and oversteered alot on a track day yesterday. Will that make things worse ?
Old 03-14-2005, 12:53 PM
stv951's Avatar
sorry Chris? What is that plate ?
Old 03-14-2005, 12:55 PM
That's the area my front tyre rubs at. My car is quite low at the front too. Mike fitted a small, sheet metal plate there to stop paint damage at full lock.
Chris
Old 03-14-2005, 01:03 PM
kqw kqw is offline
I am assuming that you are rubbing at the front fender lip?
Have you rolled the fenders?
The Fox
Carrera
Old 03-14-2005, 01:08 PM
stv951's Avatar
Yes they rub on the lips. Not rolled them yet. It also rubs inside when the steering turns (to make a U-turn etc.)
Old 03-14-2005, 01:11 PM
You do not have permissi
john70t's Avatar
The first question I ask when hearing the "rubbing" issue is why not start with ride-height and/or better yet new front shocks?
Mabye hit the apex a little less perpendicular, or become a better driver?
It seems kinda funny to take an OEM car and glue/weld on flares, complete repaint, etc, etc, when the cause of the symtom isn't established.
Old 03-14-2005, 01:32 PM
kqw kqw is offline
You mentioned measuring...What are your measurement front/back. Are you experiencing any bump steer?
The Fox
Carrera
Old 03-14-2005, 01:43 PM
stv951's Avatar
John70t: I had the car lowered for both better handling and aesthetic reasons. Shocks are Biltstein sports in good shape-not new though
kqw: I had the car adjusted to Bruce Andersons specs after lowering it. High speed is important to me as well as fast road/track handling
What would be the best compromise in settings for this combination ?
Steering is quite heavy, but I don't mind. No bump steer
Old 03-14-2005, 01:58 PM
kqw kqw is offline
You have a few choices...
As you know, rubbing can be a dangerous hazard expecially at high speeds.
You can adjust your height a few fractions of an inch and add the inner plate as folks suggested or, roll the fenders and add the plate. Either way, it's important to eliminate that lip rubbing.
No bump steer at your current front ride height tells me that your setup was done correctly.
Besides your rubbing problem, your car must handle cornering like it's on rails...
The Fox
Carrera
Old 03-14-2005, 02:11 PM
stv951's Avatar
Well its very good at the front, but I was experiencing alot of oversteer on the track - and I mean ALOT. I increased the pressures on the back as I was told by a friend from 40 to 43-44. Things were much better, but not perfect. Is that pressure too high ??? My car has 9x16 on 245s rear
Old 03-14-2005, 02:17 PM
adomakin's Avatar
looks great to me!
if you can live with the height then go for it
Andy
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 03-14-2005, 02:30 PM
What are your front pressures they might be relative to the over steer issue
Michael
Old 03-14-2005, 02:34 PM
jyl's Avatar
That seems like pretty high rear tire pressures, if those are the "when cold" numbers. Add 3-4 psi when hot and you are running at 46-48psi!
If you are really interested in your tire pressures, take a look at the SmartTire tire pressure monitoring system sold by Tire Rack. I have it and find it interesting to monitor my pressures as I drive.
I've always thought front tire pressures should be roughly 3-4psi lower than the rears, as a starting point anyway. Would be interested to hear what others think/do.
What alignment specs did you use?
Old 03-14-2005, 03:09 PM
stv951's Avatar
I'll check Smart tire pressure system. Is it accurate ?
I started with 36 fr and 40 rear when the tires were cold. Car oversteered and I almost spun in 3 or 4 occasions. Came back and added +3 psi on th rear wheels. Didn't touch the fronts, as they felt they were "glued" to the ground. I saw an improvement (6 seconds faster per lap ! so bad it was before) But still I thought it was too much pressure.
Can't recall the alignment figures as it was done some time ago.
Old 03-14-2005, 10:04 PM
Todd Simpson's Avatar
Compared to stock, the 7's add some track to the front but not additional tire width. The 9's in the rear add lots of track and additional tire. I'm surprised you're getting oversteer at all.
Pressures seem high as well. I don't have any recommendations for street tire pressures but there are some in the archives. Think about the other cars that run a 245/16. Vette's, older M5's, those are heavy cars and may need 40 pounds but not a 911.
This is apples and oranges but with Yoko A032's I run 19 in the front and 23 in the rear on a fairly lightweight RS clone with a 3.2. Hot temps are in the mid to high 20's.
Old 03-15-2005, 05:38 AM
creaturecat's Avatar
standard practise - roll the fenders
Old 03-15-2005, 05:59 AM
stv951's Avatar
Are there any issues when rolling the fenders ? Could there be damage on the wing ? Rust issues ?
Tod:
Saw your car. Looks great ! Did I read correctly ? 19 fr and 23 rear ? So low ? Aren't the tires underinflated ?
It was my first time on the track with this 911. I tried something more than street pressures. Car was very VERY nervous on lift off.
Whats your idea on fast road/track tires ? Yokos are good ?
Do they work on the street ? A friend of mine just put Toyos RA1s on his... 750 BHP 996 TT. He is very happy with these. I know, its a completely different car, but... Anyone tried them ?
Old 03-15-2005, 08:03 AM
