Administrator
These pictures were taken in the dark, but they give you some idea of the basic shape it's taken. Each 'chamber' expands in width from front to rear, in addition to expanding in terms of height.
![]() Goofy? Maybe. Effective? Who knows? I'll have to do some testing with it. I think a good way to start is the wool tufts (Can I use yarn? Maybe one black and one white strand in each tuft?) and a lipstick camera on an extended pole.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Me like track days
It has the makings of an effective setup IMO, based on sticking my head in the tunnels of wind at Boeing -
You did a nice job!
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
I would want some well placed makeup air in the back center. The GT 1's exhaust tips are in the license panel. Probably the lowest presssure spot at the rear. Good spot to divert engine air to. |
When is the complete kit going to be available? It will fit an early narrow body car, right?
Terry |
Air flow to the engine compartment is important. Jack mentioned being nervous about cylinder head temps and I was making the corellation. The airflow concern is lessened with the later water-cooled 911's and the Corvette pictured. Should be simple. If the diffuser works, and doesn't affect engine temps, then it's a winner. |
The purpose of diffuser is to exhaust any air that come under the car w/o increasing lift, the vast bulk of which has traveled under the front end and along the entire length of the car, air/ water cooling has nothing to do w/ it. Yes the air cooled pump additional hot air which also needs to be exhausted but it won't have the lift inducing velocity of the slipstream air.
I can't claim to be an aerodynamicist, and although I love it when rocket scientists debate laminar flow coefficients on these forums, I will digress....... Jack has enjoyed success in the past, and I'm sure he will tell us how it turns out.
Jack: Hope it gives you the edge (not that you didn't already have your share!) E |
So if it doesn't work as well as you want, can you lower it a couple of inches and force the air it scoops up to go over the top thereby creating downforce? An undercar wing?
Rob Channell One Way Motorsports 1979 911SC mostly stock ![]() 1972 911T Targa now with a good 2.7 ![]() 1990 Miata (cheap 'n easy) 1993 C1500 Silverado (parts getter) |
Jack,
I'm not an aerodynamicist, but I stayed at a Howard Johnson's last night. Not sure how much airflow you'll have flowing through the diffusers with the "fencing" around the perimeter. Purpose-built race cars supply diffuser air via ducts and holes in the bodywork to create the desired downforce. Or did you punch some holes in the front while we weren't looking? Hope this works well. If it doesn't pan out, it doesn't matter. It's the thought process that's important. Sherwood |
I'm terribly interested to know the outcome, Jack. It does look darn cool.
And for all of the nay sayers, Jack does back his various experiments up with practical data. He logs laptimes. Jack, yes, yarn would be fine. Other's have used yarn in the past.
Guest
Posts: n/a
An engine undertray on an aircooled hard working 911? Are you sure that's a good idea? Also how can you be sure that it won't create more lift?
I'm not worried so much about engine temps or lift, but more about drag, thats a lot of extra drag and weight being put onto the car, not to mention how it may change the handling characteristics. Jack you might have finally hit the point of diminishing return. But good luck, I hope I'm wrong. Worst comes to worst, it doesn't work out, you take it off and you're back to square one which is better than most peoples square two or three or fives
Gruppe B #22 Current: Biarritz White ‘01 996 Turbo GT2 look & 1972 Targa Carrera RS Clone w/3.6 Past: ‘75 911, ‘75 914, ‘76 914, ‘66 912, ‘68 912 & ‘01 Arctic Silver 996 Turbo |
The air cooled engine fan blows HUGE quantities of air through the cylinders and out the bottom of the engine. If this diffuser covers a portion of the bottom of the engine in such a way that it blocks the exit of this fan generated airflow the engine will not cool properly. Cylinder head temps could easily jump to dangerous levels. So the issue has nothing to do with the aero effects and is simply relative to cooling. Try having a friend hold your 911 at 5k revs then put your arm under the engine and see how much air is flowing out, you may be surprised at how much that fan pumps! The Porsche factory removed the engine undertray on the 993 racecars.... if the aero benefits outweighed the cooling issues they would not have done this. YMMV
Terry |
I also vote that the use of an under-car diffuser is effective ( from an aero/downforce) standpoint...and contemporary race cars competing against the 964 and 993 series of cars used these. I presume Porsche understands the aero benefits yet couldn't use these for their AIR cooled cars...for cooling reasons.
Who knows why they're not used on 996/997 cars? We can't presume because they're not effective.... Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
some race blueprints:
X/A |
Me like track days
It is very difficult to install a truly functional rear diffuser on a rear engined car.
Just not enough room!
Gon fix it with me hammer
then the airflow beneath the car , is allready aligned something that's difficult to achieve on a rear engined car, with a less than flat bottom, and the engine blowing it's cooling air blowing down.
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Me like track days
Yes! Although I wish it were otherwise.
