Guys,
Got a SSi Hx that has a oxygen sensor port in it. My 77 C3 engine won't need that hole. Is there a plug for that hole? Does any body know the thread size of an oxygen sensor? Or does anyone have an old dead O2 sensor that they can get me. Thanks
John F. Lewis 74' 911S Targa + 930/02 76' 914 - Eternal Type IV project FOR SALE |
Senior Member
John,
Try a normal spark plug in the hole. Believe that they are the same size! JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
According to other threads it's 18mm x 1.5mm. It's also been said that a sparkplug should screw into the 02 bung. Shouldn't be hard to find a bolt and wassher to plug.
Warren & Ron, may you rest in Peace. |
Hey, with some more spark plug wire and a little richer setting...
I see a flame thrower in my future Thanks!
Well, back to the drawing board. The hole in the SSi is much larger than a spark plug. Does any one have contact info for SSi?
Somewhere in the Midwest
John, go to the junk yard and get a couple of old O2 sensors off any car (well, most..some have smaller sensors, but they use a bushing). The 18X1.5 is fairly common. You then cut or hammer the sensor and ceramic bit off, then fill it with a weld or JB Weld. Instant plug. If you don't want to go to the trouble of a junk yard, get some cheap O2 sensors from a Farm and Fleet or the sort.
I don't believe that epoxy will hold up at those temps.
Regards, Jerry
82 911SC Targa (05 Boxster S ) gone, but not forgotten 87 Suzuki GSXR-1100 1953 MG TD Mk II |
I have 4 old Bosch sensors if that will help.
I'll check the thread and post tomorrow. If it's compatible I'll send it to you.
Guest
Posts: n/a
Oil pan drain plug (not Porsche). Go to Napa - they'll fix you up.
When someone mentions "sparkplug size"....I hope it's clear that it's not a Porsche (14mm) plug...denoted by a "W" prefix using Bosch nomenclature...but a "D" 18mm plug from some other car....right ??
Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
" Is there a plug for that hole? "
I have a note that says a Toyota Truck drain plug has the same thread dimension (M18 x 1.5). Hope this helps, Sherwood http://members.rennlist.org/911pcars |
I ran across this website. Seems like they have what you need:
http://www.belmetric.com/html/catalog16.htm Hope this helps, Sherwood |
Hey Guys,
I went to Standard Auto Parts and got a generic M18 x 1.5 drain plug. It worked like a champ ![]() Thanks alot!
