Can I drive the car without it? Will I break the clutch cable or pedal doing this?
The long story is described here - Clutch engagement clicking I am getting to a point where I think I might want to bring another new spring to a competent mechanic to install it properly for me ![]() thanks...
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
You shouldn't break anything immediately but over time you will oval the pin hole in the pedal arm for the cable. Lube the stink out of the cable pin in the pedal cluster in the meantime, then get the helper replaced -- soon.
hobieboy, is it possible that you put the spring in backwards? If I recall correctly, it is possible to do. That may be the cause of your problem. Look at Wayne's 101 book for the proper orientation. I do not have mine handy, or I would check for you.
99 996 C4 11 Panamera 4S 83 SC Targa converted to a 964 cab (sold) 67 912 (sold) 58 Karmann Ghia choptop (traded for the 912) |
David,
Thanks for the reminder... but am sure the orientation is right. I found my old spring & installed it. The pedal is now a bit lighter, but still a strange problem - it does not disenegage the clutch completely. It moves the splined small arm only by ~1cm. Factory said it should be 2.8cm. I really ran out of ideas...
