project 72 coupe (need some help)
Hi
need some help here I have finaly found my project car. ( I hope) im looking at a 72 sunroof coupe , the car itself looks like it can be saved with some new rockers heres my questions the car has been updated to 74 style (hood, fenders, ect.. and a fiberglass front bumper) deffinately not what i want. How hard is this to reverse and go back to the long hood and what had to be done to the lock to get this to fit do you think the front end is still original or has it been hacked to get the 74 stuff to fit I will try to upload some pics really would apreciate all info thanks |
![]() Not pretty but a good starting point I think!!!!!! Last edited by herman maire; 04-20-2005 at 08:40 PM.. |
Do you think the nose is still a 72 or has it been hacked |
Warren Hall Student
The front latch panel gets replaced when converting an early car to late car styling. You can replace the panel with an early one but you also need a bit of sheet metal to extend the sides that were trimmed when the late panel was installed.
The other option is use RSR hood latches to secure the long hood and for go the early latch panel. If you have difficultly in locating early fenders at a reasonable price you can make do by getting a rusted pair as donors for the turn signal boxes that can be cut off and welded to the late fenders to convert them.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
I think that the front latch panel is the biggest job. If you poke your head inside you should be able to tell how it was converted the first time (ie. at the seam or spliced in).
Tim K |
beat me to it.
Thanks bobboloo
so if i keep the front latch panel and put the long hood on will the early bumpers or RS bumper work. What do you think this car is worth? is has not run for 3 years needs rockers bad! motor and tranny should be okay On the fan housing it says that its a 163.9 cu.in i think so a 2.7 but it has mechanical fuel injection what motor could this be? is this car worth messing with |
Where are you located in Canada? I am finishing up a 69 911 T restoration north of Vancouver. How much it is worth depends on if you are doing the work yourself and what you plan to do. If you need rockers, you will most likely need inner and outer and you may as well replace the jack receiver tubes and supports while you are in there (price it at Restoration Design, that is where I got most of my sheet metal and they fit great!) It will need paint...this is at least 40-60 hours in a body shop. If you need engine work done, you could budget anywhere from a few hundred tuning it to 4-8000$ Canadian. If you really want an early car, I would look for one, you will need to get alot of welding done to convert it back. I would not pay more than $5000 for the car, but that is just in my opinion.
Derek
1989 964 Carrera 4 Coupe |
Get as many numbers as possible off the engine and MFI. Check and see that the tranny is original and if not, what type it now has. Still have early rear bumper with the duck?
Are the late model panels nice enough to resale? Value? Will the engine turn over? Have you tried a compression or leak down (realizing after not running for this long they will be artificially low...use this to your advantage) Have the oil changed and see if she'll fire. Find out what the drivetrain is like/type. How bad are the brakes, did it sit outside the whole time? Is anything in the interior worth using? Non running, non original engine, sat for three years, ratty interior, no paint, cookie cutters, non original body work, corroded brakes: I'd offer $4500. If your in love I'd go higher, but I'd start about there. If he hasn't driven it for three years, he's not in love with it. I paid about $4500 for a roller with new Koni's, uprated bushings and TB's, glossy one season paint job, new brakes, new carpet and BMW buckets, and 15x6 Fuchs about a year ago.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
Warren Hall Student
I myself wouldn't pay more than $3500 US for the above car but that's just me. I know the early cars are getting harder to find but they are out there if your persistant and patient. I just sold my 72' Coupe with a fresh rebuilt 2.4T w/ MFI for $6500. New clutch, brakes, good tranny. It wasn't without issues though. It had been hit on the passenger side and repaired improperly so I figure it needed atleast $2500 in panel work to make it right.
Please call me next time you give a 72 T like that away Bobby.
'72 911 T/E Silver Targa |
I would thoroughly disassemble and clean out the entire fuel system before turning it over. The whole system is contaminated with old fuel (varnish) and will add greatly to your problems, unless systematically removed. I wouldn't want to ingest what's in there into a $500 fuel pump, or injection system.
There's a lot of info available here (search key) to help you along .
Mike B. '72 911E Coupe Early "S" #1065 |
nice doggie
Are the rockers rusted out or is it just missing the covers?
Jerry 78 SC hotrod 02 Mini Cooper S |
I bought a TRE fiberglass hood for my project which has the hood latch to fit the short hood latch panel. Call Dave at TRE Motorsports. The hood is pretty slick, but allows you to keep the later bulkhead without moving it. My car is being backdated, but was previously updated. So it is actually a 71 with a later style hood latch panel.
Doug
1971 RSR - interpretation |
thanks for the replys. Huge help.
This cant be said enough but pelican is an awsome place. I dont know how to quote so i will try to answer some questions dgagne- I live in tremblant , quebec pretty similar to whistler, bc but the ski hill is a third the size. As for the work it will be my brother and I doing all the work would much rather pay someone but funds dont allow that right now, should be fun also For the drivetrain i was told it ran strong a little puff of oil on start up and thats it and it didnt burn any oil. Could be a load a c$#% who knows i hope he is telling the truth . |
Lukesportsman- Ya it has a ducktail. I still have to check the engine # and tranny.
$6500 woooow that looks like a pretty sweet car for the money. I will probably be over that just buying welding wire for the mig welder lots and lots welding wire. $3500 ya i know thats all i would like to pay but youre in L.A , project cars are everywhere finding one out here is like striking oil( no joke ) thanks for the reply |
real550a- I deffinately plan on cleaning up the injection
hetmann - Rockers are gooooooone who knows what else probably the inners also Dwsd- that sound like a good compromise I will check them out saves some weight also |
does anybody know what the deal is with motor checked it out and its a 2.7 with mechanical injection is that possible? can mechanical injection be fitted to any 2.7 74-77 |
another question Is that the engine serial # on the fan housing?
and should this # match the # on the case? Last edited by herman maire; 04-21-2005 at 07:44 PM.. |
any ideas on the motor
what should i look for to identify it i have a few porsche books but not too much attenion to serial # |
