All those who rebuild their engine
Hi all,
I am in the process of doing a top end rebuild on my 964. I am document the diff between the 964 and the Carreras in the Engine Rebuilding Forum. I am at the point where I am reassembling the engine, and would like to seek your experiences on where you have oil leaked when you installed your engine and run it for the first time. Hopefully, this will help me put together a leak free engine. thanks, anthony |
Air Medal or two
I think the 964 is a just like a 911 only....different.....mabe thats why no replys........h2o heads??
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
I had a few rocker shaft leaks, cured with the RS rocker seals at about $1 each. I'm not sure if these fit 964 shafts, but it would be worth looking into. Maybe JW knows....
993 |
Senior Member
Talk to JW. He's got some fairly conclusive opinions on sealant, etc.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Semper drive!
Surely you went a little overboard with the number of words in that sentence of yours. ![]() Of course JW knows. ![]() Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )One Marine's View Igitur qui desiderat pacem, praeparet bellum |
I've already ordered the RSR rocker seals. Will find out how it fits.
Just looking for areas where people are prone to make mistake a end up with a leak. I am tempted to put Curit-T or some other sealant on every o-ring. But that may be a bad idea. |
Senior Member
Dow Corning 111 or 112 goes on o-rings. Talk to John about sealant.
Where in TX are you?
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
993 |
Crusty Conservative
Pinching the O ring that seals the camshaft where it goes into the back of the chaincase(s) is a BAD thing. Oil at engine pressure here, as close to the outside world as it gets..
A BIIIIIIIIG PITA to fix, as well.
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
