Eric Mckenna's Avatar
RSR front strut part# is there one?
If not who made them BILSTEIN only or did anyone else make them as well?
Thanks guys!!
Famous last words..
"Hold my beer and watch this...'
" The reason the Irish are always fightin one another is that there are no other worthy opponents ".
Old 04-28-2005, 09:08 AM
anyone......
Famous last words..
Old 04-28-2005, 09:46 AM
George K helped me out..
So I have my answer..
-Eric
Famous last words..
Old 04-28-2005, 10:16 AM
Are the strut housings threaded or not? RS Struts should be full threaded and yes, they will say Bilstein stamped into them. The spindle should have a 30 mm height increase so as to lower the vehicle and a welded on reinforcement on them. But, threaded housings will be the tell-tale sign.
Old 04-28-2005, 10:40 AM
Thanks..
The ones that I have were .. "said RSR" struts but they are just BOGE sturts.. I know you can still replace the inserts... but they are still not Bilstein RSR. they have no triangular brace nor were they the green they were painted by someone.. not from the factory they were black I am sure as the paint under the green was black.. so I am sure these are just BOGE struts that were painted up BILSTEIN green and maybe has a revalved insert but not real deal RSR strts..
Thanks for the post though..
-Eric
Famous last words..
Old 04-28-2005, 11:12 AM
Porsche Doc's Avatar
Here is a real RSR front strut.
Thanks!
Don Ramsay E Mail: aircooledclassicsporsche@gmail.com
The father of 964 Backdating!
www.aircooledclassics.co
www.facebook.com/AirCooledClassicsPorsche/ www.instagram.com/aircooledclassicsporsche/
Old 04-28-2005, 11:20 AM
I do not think the 2.8 RSR strut is threaded at all.
The RSR moniker has been misused too often on struts. It has been used to describe Bilstein struts, with or without reinforcments, with or without raised spindle, or to describe a specific shock valving which is nonsense considering the factory had a lot of different valving for different tracks and diferent weathers. I'd hate to use a RSR strut from Monza on the Safari, yet both were threaded (in 74) and both had strehnghtening plates.
Old 04-28-2005, 11:56 AM
Yeah that is NOT what I have......
The ones I have are BOGE that were painted to look like BILSTEINS
-Eric
Famous last words..
Old 04-28-2005, 11:57 AM
