Do need to primer glazing putty?
Hi,
Just wondering if I need to primer glazing putty befor top coating? It is Everclear (ever something) G P.
Thanks,
Old 05-03-2005, 05:38 PM
How much glazing putty did you slather on? If it's just tiny pinhole fills I wouldn't worry about it. If you have 4x8 inch sections, then yes, re-prime.
Old 05-03-2005, 05:42 PM
It is not that big. It is small line. I'll give it a try.
Thanks,
Old 05-03-2005, 05:45 PM
blue82coupe's Avatar
Argeo. The last time I drank Everclear I went blind for about 6 hours. I think the stuff is called evercoat. I would spot coat it with a sealer/ primer. Dan
I have plenty of lead for my pencil... just not enough paper to write on..
82SC with 95 993 engine
2004 Ford Powerstroke
Old 05-03-2005, 05:48 PM
any non catalyzed filler is going to shrink and the repair will be visible thru the paint soon. just use regular bondo with hardener for those skim coats. putty in a tube is not the way to go.
206 637 4071
Old 05-03-2005, 06:06 PM
flipper's Avatar
I second John Walker
2005 911 carrera
57 BMW r50, 2007 Ducati s2r 1000
2007 Boxster (sold)
77 2.7 911s chocolate w/ducktail (Mr Hankey) (sold)
77 930 black (sold)
Old 05-03-2005, 06:07 PM
Thanks guys. This stuff uses a hardener. I am now a true believer in bondo. I have had a spot on my thumb nail of Everclear bondo (the mid strength stuff) for like three weeks now. Oh, and I shower once a week too.
Thanks,
DAVID
Old 05-09-2005, 01:08 PM
FWIW, (To echo JW) I almost always have had problems glazing anything bigger than a pinhole....and I do mean Anything bigger. The product I've used is called Nitrostan.
It's very tempting to use this stuff on slight depression, large scratches etc. I would allow the primer applied over the glazing to cure for quite some time.
Just my 2c.
Warren & Ron, may you rest in Peace.
Old 05-09-2005, 01:15 PM
IMHO, It's best to use a system.. whether it be a Glasurit product, Dupont ,PPG, Sikkens or whatever. I believe it's risky to mix and match products. The putty in a tube, is lacquer based product, It shrinks like crazy. Dan
Old 05-10-2005, 05:57 PM
