ausgezeichnet's Avatar
New Wires- WOW!
I just replaced the plug wires the PO had on the car with a set Clewetts from our host. What a difference! I've got power across the band and engine runs much smoother. These wires an a fresh set of plugs are the best money I've spent so far. I had NO problem getting the Clewetts to seat properly. Got it right the first time. In retrospect it should have been the first thing I did when I got the car. Can't wait to get rid of the clogged cat and open up the muffler to a two out. Now it gets fun!
Mike
'84 911 Carrera Coupe (totaled)
'83 911 SC Coupe
‘06 Aston Martin Vantage V8
Old 05-09-2005, 05:44 PM
Did you reuse the Beru wire separators?
Joe
Old 05-11-2005, 06:30 AM
No, but I did not take a lot of time with it. The channels in the seperators seemd too tight. I'll probally try again soon.
Mike
'83 911 SC Coupe
Old 05-11-2005, 10:33 AM
Gumba11's Avatar
How bout a pic of your car Mike?
77 930 "P Zilla" 3.2 Litre w / EFI conversion
Old 05-11-2005, 10:35 AM
Sure!
how about a pic of yours. Is that Portland Maine or Oregon? I used to live in Salem.
Mike
'83 911 SC Coupe
Old 05-11-2005, 10:41 AM
Mike,
I'm not using the separators either and I doubt I will go to the trouble since everything looks and works just fine.
Joe
Old 05-11-2005, 11:35 AM
Joe,
Are you using Clewetts?
-Mike
Mike
'83 911 SC Coupe
Old 05-11-2005, 11:42 AM
No but a modified set of Chrysler cables that are virtually identical to Clewetts.
Joe
Old 05-11-2005, 05:16 PM
Chrysler LH ignition wires on my 86 3.2
Cheers,
Joe
Old 05-16-2005, 02:16 PM
randywebb's Avatar
They are a ton cheaper, right?
Want to post the p/n and what mods you made to use them - might help others.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-16-2005, 02:23 PM
Since it started out as an experiment I went the really cheap route of stipping them off a 95 Chrysler LHS at Pick 'n Pull. I think they charged me $12 for the set.
The cables come too long so they have to be cut to size and the connectors on the cap end have to be re-crimped back on. Next, slip them back on the stock Beru boots for a stock look on the distributor end.
Joe
Old 05-16-2005, 03:54 PM
