J Smith's Avatar
Rick - No, unfortunately, I have this nagging responsibility known as work, which really bites right now. I was having thoughts of trying to get in last minute, but my wallet is telling me otherwise. I will be at Watkins Glen in 2 weeks though. I'm real happy about that.
Have fun. You fellas are entertaining to say the least.
Josh
'87 911 Carrera 3.2 Coupe
Old 10-09-2005, 10:46 AM
MysticAlpaca's Avatar
Send a message via Yahoo to MysticAlpaca
Originally posted by Carrera3.5L
What do you pansies need heat for? Just wear a jacket.
Ralph
Where do you get that nice silver Porsche logo'd fan housing cover thingy..lol not sure what its called. Mine is all dirty, I plan on cleaning it when i put my new plug wires in this weekend but would like to have a nice logo'd one isntead.
--bill
87' Red Targa
10' Jeep Wrangler Unlimited
07' Subaru Impreza (lease ended)
02' Mini Cooper S (traded )
91' VW G60 Corrado (sold )
Old 10-13-2005, 02:10 PM
Send a message via Yahoo to drophit
WHERE can i get the cool red hosing from !!!!
Z
Old 10-14-2005, 02:54 PM
DW SD's Avatar
Pelican sells some, I suspect. I bought mine from Aircraftspruce.com 2.5" SCEET high temp silicon coated, wire framed ducting. It is about $10 / foot. Did my whole car with about 8' - 10'. Look in airframe section. VERY nice quality.
Doug
1971 RSR - interpretation
Old 10-14-2005, 02:58 PM
Is it this
http://www.aircraftspruce.com/catalog/appages/sceet.php
Z
Old 10-14-2005, 03:09 PM
DW SD's Avatar
yes
Old 10-14-2005, 03:12 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
--bill
Bill,
My fan strap has simply been powdercoated (along with all of the other engine bits) and I affixed the decal on top as a personal touch. The decal was given to me from my ex-coworkers at Porsche Motorsport. They are pretty stingy with them, good luck getting one without having your GT3RSR motor serviced by them.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 10-19-2005, 09:01 PM
efhughes3's Avatar
Just ordered a couple of resistors per Kurt's update on his backdate. I couldn't find a 51ohm/15W, but did find 10W and 25W versions. I ordered one of each to meet the $10 minimum, and see what happens. I'll update when I get it in.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 10-21-2005, 05:53 PM
wcc wcc is offline
wcc's Avatar
I've started to backdate my engine compartment. I removed the factory air box and put a fresh air intake on. Then I removed the AC compressor, belts and hoses. I was wondering how to remove the bracket that holds the AC compressor (see yellow arrow in pic). I found a couple of bolts up towards the top, but it's the bottom part that I can't figure out. Any help would be appreciated.
Thanks,
Bill
Old 10-24-2005, 07:44 AM
MBruns for President
JeremyD's Avatar
Two main ones on top of the engine tim metal = by the side of the fan housing. One just to the rear of the arrow.
Down below the sheet metal - there are two more (I believe)
You;ll probably have to remove the muffler to get to them. You can see it pretty clearly here:
Old 10-24-2005, 07:59 AM
wcc wcc is offline
wcc's Avatar
Then it'll pull right out?
Old 10-24-2005, 08:14 AM
JeremyD's Avatar
Yes, you might have to losen the engine sheet metal a little on the right side - but yes...
Old 10-24-2005, 08:16 AM
wcc wcc is offline
wcc's Avatar
Ok, thanks. I've just changed my muffler to a Borla so it'll be easy to get to those bolts on the bottom.
Thanks again.......
BTW SWEEEEEEET lookin' motor!!
Old 10-24-2005, 08:17 AM
efhughes3's Avatar
Anyone find out anything on the Auto-heat/footwell blowers? The resistors I bought did nothing.
Ed Hughes
2015 981 Cayman GTS
Old 12-31-2005, 06:29 PM
How about a resistor in the plug for the (disconnected) heater blower?
'84 911, some sort of red color
'05 Subaru WRX wagon
Old 06-17-2008, 10:06 PM
Does anyone know if this backdate works on a '85 930? If so, it would resolve my lack of heat since my headers don't have the heater boxes...I think quite a few of turbo folks are in the same boat as me and would really appreciate this option.
Let me know if this would be better served if posted on the 911 turbo section.
1985 redslope 930, 8:39 RP, S cams, B&B dual out muffler, IA Fuel Dist. Sitting on shelf awaiting installation: IA HF turbo, GSF headers(no heat), 46mm wastegate.
1971 911T Targa. needs alot of work(understatement).
Old 06-17-2008, 10:41 PM
gtc gtc is offline
abides.
gtc's Avatar
This has been tried. The resistor eventually failed.
This thread details a simple jumper you can add to the heater blower relay that will enable the footwell blowers to function after you disconnect the rear blower.
FWIW, I backdated the heat when I installed my B&B headers, and now my heat is MUCH weaker. I'm not sure if it's the headers or the new heater tubes.
Originally Posted by bolt View Post
Does anyone know if this backdate works on a '85 930? If so, it would resolve my lack of heat since my headers don't have the heater boxes....
930's already have a heater duct similar to what is used to backdate the 3.2s.
I'm afraid that if you have aftermarket headers with no heater boxes, you're SOL...
Graham
1984 Carrera Targa
Old 06-17-2008, 10:55 PM
efhughes3's Avatar
I did the jumper outlined by Mystery Train-It works.
Ed Hughes
2015 981 Cayman GTS
Old 06-18-2008, 09:51 AM
sbrown.nw's Avatar
wcc,
Which air filter do you have? I have a larger K&N one with a slightly modified intake on my 3.2.
Thanks,
Scott
QUOTE=wcc;2194448]I've started to backdate my engine compartment. I removed the factory air box and put a fresh air intake on. Then I removed the AC compressor, belts and hoses. I was wondering how to remove the bracket that holds the AC compressor (see yellow arrow in pic). I found a couple of bolts up towards the top, but it's the bottom part that I can't figure out. Any help would be appreciated.
Thanks,
Bill
[/QUOTE]
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC now
- 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs
Old 06-18-2008, 12:24 PM
Great thread.
I think I know what to do w the hole left in the rear tin where the ducting used to go.
Fill it with a charge pipe from a turbo. Is it in the right place?
Old 06-18-2008, 02:32 PM
