02 sensor wire location
On my euro 1980Sc PO has removed the 02 sensor and I also don't see the wire for it. Were does this wire connect to?
I'd like to hook it back up for fuel economy but there are no tell tale signs of a disconnected wire.
There is a bung on the cat bypass pipe so I assume it had a 02 sensor at some point.
Silver 1980SC Euro coupe
Old 05-10-2005, 09:14 AM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
One of the wires connects to a fuse inside the passenger compartment under the cover on the left side of the engine compartment - under the cover that is held on by the two wing nuts. I disabled mine by disconnecting the power to it, but then reconnected it after it ran poorly?
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 05-10-2005, 10:32 AM
So one goes to the fuse panel and the other goes?
Anyone?
Old 05-10-2005, 11:14 AM
Anyone?? Hello? Is this thing on?
Old 05-12-2005, 05:43 AM
