Why A Rough Idle After Tune-Up?
I changed out my spark plugs, replaced my fuel filter and changed the oil and oil filter and after start up, it idles a bit rough. Its the 2.4, 1973.5T CIS engine. I went back to check my spark plug connectors, make sure I did not bump any vacuum, gas or electrical lines, and yet its till on the rough side. On the road it runs like a bat outta hell in all gears throughout the rpm ranges, but its very peculiar why this happened.
Can new spark plugs cause an issue? Richen up the mixture?
Any advice is always appreciated from you folks.
Bob
73.5T - CIS
Old 05-12-2005, 12:12 PM
copper's Avatar
Although you didn't mention it, I assume you gapped your plugs correctly...
Jim Dean LL.B. - London, Ont, Canada.
1969 911T "Blood Orange" Euro (Brought over from Germany in 86)
Engine and brake system rebuilds 2006 & 2007
"Oversteer scares passengers, understeer scares drivers."
Old 05-12-2005, 12:21 PM
I used the right plugs and gapped correctly. The idle is a slight intermittent miss, that although is not very pronounced, was not present before. Its a mystery to me.
Bob
Old 05-12-2005, 01:49 PM
Assuming your ignition cables are old stock Beru, disturbing them with a tune up might be enough to cause them to fail.
Joe
Old 05-12-2005, 02:16 PM
Designer King
Paulporsche's Avatar
Assuming you used the same/ correct plugs.
Did you check your rotor, cap,timing, and dwell?
Maybe your dwell & timing are off but you didn't notice it before.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-12-2005, 03:35 PM
If you have a pop off valve you might make sure it's seated.
Joe
Old 05-13-2005, 08:49 AM
