Is my engine cooling effected......
by the gap in the fiberglass engine tin on the left shown in the picture? This is my 3.6 engine that is using early cross member and fiberglass engine tin. There is a rather big gap as you can see in the left of the picture. Should I cover this area like the right side for better cooling or is this not a problem?
If it were me I would cover it.
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Stranger on the Internet
Where does the oil cooler go on a 3.6? Shouldn't it be over there somewhere?
Patrick E. Keefe 78 SC |
Pat:
3.6 motors do not have engine-mounted coolers; there is a pressure side oil filter mounted in its place.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
![]() Only the 993 has a filter there
Thanks Bill, I will cover the gaps......
