LinkBack Thread Tools Rating: Thread Rating: 4 votes, 1.00 average.
Send a message via AIM to 82SC
roll bar padding
where do you buy that foam tubing, that you can cut and zip tie over a roll bar?
home depot?
thanks
MJ
Old 05-23-2005, 01:35 PM
304065's Avatar
MJ,
There is only one kind of foam you want, and that's the high-density kind that is SFI rated. The trouble with the Home-Depot plumbing wrap is that under any kind of impact it compresses and doesn't cushion your helmet against the rollcage at all. Also, that stuff will melt if it catches on fire and drip on unprotected skin, bad outcome.
http://www.longacreracing.com/catalog/item.asp?id=1193&catid=21
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-23-2005, 01:45 PM
coloradoporsche's Avatar
I was told in no uncertain terms by my friends in the local Porsche club NOT to buy the foam from the hardware store. There is much better stuff made specifically for racing that you will find by doing a search.
I bought SFI rated padding from Summit Racing and it has nice Velcro backing on it to hold it in place. It's more expensive than foam from Home Depot, but it will protect you head much better in a crash.
Regards,
Sheena is a punk rocker
Suzy Is A Headbanger
Heidi Is A Headcase
Judy Is A Punk
The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'."
Administrator
Jack Olsen's Avatar
Even the race houses will sell you the useless 'nerf bar' padding. Don't get it. Like everyone else says, you should get the SFI rated high-density stuff.
Old 05-23-2005, 01:47 PM
greglepore's Avatar
The other option is Longacre padding, which is very similar to SFI but technically not "SFI rated". Just went thru this today.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 05-23-2005, 02:14 PM
