roll bar padding
where do you buy that foam tubing, that you can cut and zip tie over a roll bar?
home depot? thanks MJ |
MJ,
There is only one kind of foam you want, and that's the high-density kind that is SFI rated. The trouble with the Home-Depot plumbing wrap is that under any kind of impact it compresses and doesn't cushion your helmet against the rollcage at all. Also, that stuff will melt if it catches on fire and drip on unprotected skin, bad outcome. http://www.longacreracing.com/catalog/item.asp?id=1193&catid=21
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
I was told in no uncertain terms by my friends in the local Porsche club NOT to buy the foam from the hardware store. There is much better stuff made specifically for racing that you will find by doing a search.
I bought SFI rated padding from Summit Racing and it has nice Velcro backing on it to hold it in place. It's more expensive than foam from Home Depot, but it will protect you head much better in a crash. Regards,
Sheena is a punk rocker Suzy Is A Headbanger Heidi Is A Headcase Judy Is A Punk The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'." |
Administrator
Even the race houses will sell you the useless 'nerf bar' padding. Don't get it. Like everyone else says, you should get the SFI rated high-density stuff.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
The other option is Longacre padding, which is very similar to SFI but technically not "SFI rated". Just went thru this today.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
