bigchillcar's Avatar
Rennaire procooler really drop vent temps by 20 degrees??
thinking hard about this..i've read the threads. i've got the sanden rotary already..not sure if i have updated barrier hose or not - they can't be original, definitely replaced (is there a way to tell for sure?)
anyway, i appear to only have the rear condenser..if there is one in the front, i'll be damned if i know where it is..my evaporator and blower motor all work fine. if just adding a $300 procooler will honestly drop my vent temps a true 20 degrees..i'm way satisfied with that. any testimonials on adding just the procooler for a 20 drop? i think i;d be willing to do it for even 10 degrees!
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 05-16-2005, 10:45 PM
Not Quite Banned
Thomas Owen's Avatar
I had a procooler on a '78 and it did help, but it was not a Miracle Worker. What you have to keep in mind is that if the system is working properly, the Procooler will lower the vent temps (how much probably varies). If, on the other hand, your system has a problem, like a slow leak, clogged fins on the evaporator or condenser, poor compressor, the procooler will probably not make you see any difference. In other words, it will not 'fix' a problem, only 'help' a normally operating system.
Good luck, and post your results-
Thomas Owen
1972 911T
1972 911S
Old 05-17-2005, 05:23 AM
scottb's Avatar
Ryan: I've got a ProCooler, and I'm very happy with the results. 20 degrees? Not likely, but it's definitely helped.
Also, the Sanden is NOT a rotary condenser. Go to their web page and you'll find out that it's a wobble plate, piston compressor. As far as I know, the only true rotary is the Seiko.
Do a search here on the board. I think Jim Sims (our resident a/c guru) posted something on how to tell whether you have barrier hoses. The bottom line is that you should not waste your time working on the a/c without either (a) knowing the hoses are barrier, or (b) installing barrier hoses yourself.
If you have a front condenser it's in the very front of the car. It's easiest to see it if you kneel down in front of the car, and look up. It's protected by a mesh screen, and it's behind the "skid bar" or whatever that curved tube is in the front that protects the underside of the car from steep driveways. Also, if you look inside the trunk, in the front right corner, you should see a large cooling fan that pulls air across the condenser.
Good luck.
1984 Targa
Old 05-17-2005, 05:26 AM
greglepore's Avatar
Ditto. 20 degrees? No way. It does help. Moving, I have high 30's vent temps on 134 with a stock system and a procooler. Biggest issue for me is airflow over the condesor in traffic; some folks have added small 12v fans, which seems like a logical improvement.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 05-17-2005, 06:25 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
How do you think this would work?
New lines, condensors cleaned, Sanden 507, R134a, small fans attached to decklid condensor.
Waste of time to get procooler or make one?
Old 05-17-2005, 06:32 AM
scottb's Avatar
Small fans are prolly a waste of time. Add a condenser and a Procoler.
1984 Targa
Old 05-17-2005, 06:35 AM
Add a condenser, barrier hoses and charge with R-12.
See the following:
Griffith's fender condenser dimensions
I beg to differ with Scottb on the fan, when used in conjunction with an additional condenser it does provide some support during stop and go traffic.
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 05-17-2005, 06:44 AM
scottb's Avatar
Bill: Do you really think some small fans on the rear decklid condenser help? It seems to me that the engine's fan, even in traffic, will pull more air across the condenser. I agree that a fan on an additional condenser is a must (I did it on my front left condenser), but adding little fans to the rear condenser seems to be "a pea in the ocean."
1984 Targa
Old 05-17-2005, 06:46 AM
si Banker's Avatar
Pro Cooler
I just finished adding a Pro Cooler, new lines, a larger serpentine condenser on the rear and a new serpentine evaporator. Using R-134 the results are unbelievable. It works like a real AC system!!!!!!!!!!!!!
I do not know which of the changes made the most difference but the combination is super.
scottb's Avatar
si Banker: Tell me about the large serpentine condenser. How did you fit it? Can you post pics?
1984 Targa
Old 05-17-2005, 06:48 AM
Scott,
I used a single 9" spal fan and it seems to have helped. It was installed at the same time the rear fender condenser so I can't really say what the contribution is. I can say that the air moving directly over the fan throught the tail grill / condenser is significantly greater with the fan. I could test the effectiveness of the fan by disconnecting it and checking pressures and temps though that might be way too scientific. Also if it turns out the fan makes no contribution I might feel the A/C is less effective. Remember its all about perception.
Bill
Old 05-17-2005, 06:59 AM
What about ditching the tail condensor altogether and help imporve engine cooling? Run an aux. condensor in the wheel well?
Old 05-17-2005, 07:03 AM
jdowty3's Avatar
You can get rid of the front and rear condensors if you install a 964\993 front wheel well condensor. If you take the system apart to install barrier hoses, source the hose locally and get it in bulk. Way cheaper. I replaced all my hoses and fittings for about $200. I bought my hose and fittings from HoseFast in Dallas but most cities have someplace the local mechanics use for custom brake lines and AC.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 05-17-2005, 07:45 AM
si Banker's Avatar
Pro Cooler
The condenser is custom made by a shop here in Fort Worth. It is about half again as larger as the stock one, which I am selling for $175.00, and is curved like the radiator on a sport bike. He described it as a serpentine condenser.
The fit is very tight and it comes with the necessary hardware. I can assure you the results are worth it.
Old 05-17-2005, 07:46 AM
scottb's Avatar
Re: Pro Cooler
Can you post a picture, and the name of the shop that did the work?
1984 Targa
Old 05-17-2005, 07:51 AM
will the 964/993 condensor fit in the front wheel well?
scottb's Avatar
Why would you want to decrease condenser surface. The key to effective a/c is heat exchange. The more condenser surface, the more heat exchange. The more heat exchange, the better the a/c.
It seems to me that you'd want to add the 964/993 condenser in addition to the existing condensers. Am I missing something here?
1984 Targa
Old 05-17-2005, 08:01 AM
Jared,
Listen to Scottb, he's so smart
Bill
Old 05-17-2005, 08:04 AM
Metal Guru
911nut's Avatar
I think Jack Olsen uses a Performance Aire belly condenser instead of an engine lid condenser with good results. Hopefully he'll chime in here.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 05-17-2005, 08:13 AM
I have no desire to put a condensor under my car... I probably cant afford it anyway....
Does the 964/993 condensor fit in the wheel well?
Old 05-17-2005, 08:16 AM
