-   -   Reconstructing Constant Velocity (CV) Joints (http://forums.pelicanparts.com/porsche-911-technical-forum/222537-reconstructing-constant-velocity-cv-joints.html)
rcecale 05-20-2005 09:10 AM
Okay, fellas, Sunday School is over! ;)
Now, getting this thread back on-topic....
Just placed my order with Glenn at Pelican. going with the following:
- 4 Boot Kits for re-doing the boots on both ends of BOTH axles. P/N: F-332-924-02
- 24 new cap-screws, P/N: 900-067-123-01
- 24 new Schnorr Washers, P/N: 999-523-103-01
- 12 new Moon Clips, P/N: 911-332-191-00
A big "Thank you!" out to Randy Webb for this thread. It proved to be a valuable resource for locating the proper part number for the Schnorr Washers. Also just a great thread that should help with refreshing of my axles.
Randy
pwd72s 05-20-2005 09:21 AM
Good news Randy...let us know when you're running again. Big chill & Ron? Sometimes, just sometimes, I miss the smell of the incense...
rcecale 05-20-2005 10:49 AM
Originally posted by randywebb
Thanks - glad it helped!
Send your beer keg donations to me in greater metro Nimrod, Oregon at 666 Twisty Lane. We have a suite on the 75th floor of the Trans-Orygun Bldg.
Randy,
Do you have a PLAY-pal account? ;)
Randy
rcecale 05-20-2005 03:33 PM
Okay, now it's starting to get real interesting.
Decided earlier today that since I was installing new Boot Kits on the inboard ends of the axles, I may as well do the outboards too. Went out to the garage a bit ago and was instantly stymied.
My question here is, do I need to remove the tires and brakes and stuff to get to the bolts for the outboards, or can I just move/slide that cap along the axle shaft to get to the cap screw heads. Don't want to force anything and mess it up.
I suppose I could spring for a Bentley's about right now, but then what would that do for sharing this information with everyone else?
Randy
rcecale 05-20-2005 03:40 PM
Found this pic on the WWW.
http://forums.pelicanparts.com/uploa...1116632391.jpg
Looks as though I should have access to the cap screws on both ends. I'll go out and have a closer look-see. I'll take my trusty camera with me too. ;)
Randy
rcecale 05-20-2005 03:58 PM
Well, that didn't take long. Here's what I found.
Passenger Side - Outboard, with boot pulled away.
http://forums.pelicanparts.com/uploa...1116633229.jpg
Passenger Side - Inboard
http://forums.pelicanparts.com/uploa...1116633288.jpg
Driver Side - Inboard
http://forums.pelicanparts.com/uploa...1116633358.jpg
Driver Side - Outboard
http://forums.pelicanparts.com/uploa...1116633385.jpg
There certainly doesn't seem to be access to any cap screws on the outboard ends. Am I not tearing into this far enough from underneath? Or do the wheels and brake assemblies need to come off to allow access?
Randy
Beethoven 05-20-2005 04:03 PM
There goes Randy again with his stunning photography--notice the deliciously placed red object to give the composition just the right kind of contour? The Cartier-Bresson of garage photography!
rcecale 05-20-2005 04:13 PM
Beethoven, are you trying to tell me something??? :eek:
http://forums.pelicanparts.com/uploa...1116634396.jpg
"Arizona" Henri Cartier-Bresson, 1947
Randy
bigchillcar 05-20-2005 05:03 PM
hilarious, beethoven! you can't hear, but great eyes..very good show..:)
ryan
randywebb 05-20-2005 05:11 PM
I think people with 'new' cars - like yours - have to pull the whole axle. Earlier cars, up thru the SC (?) don't. My basis for this is seeing a lot of posts with Carrera owners cursing about the 300+ ft-lbs on the wheel nut...
You DO need a Bentley - false economy not to have one.
Good Luck.
rcecale 05-20-2005 05:14 PM
Okay, not sure why I didn't think of this before, but replacing the CV joints is Project 41 in Wayne's 101 Projects book.
Read through that and found the answer I was looking for on Pg. 115.
"On these later cars, the outer CV joint is not available seperately, but must be purchased as a complete axle. This is because the joint is integrated into the stub axle and cannot be separated."
Looks like I ordered the wrong stuff. Putting a call into Pelican tomorrow to change it. Hopefully they haven't shipped it yet. Haven't received the e-mail yet, so....
Randy
rcecale 05-20-2005 05:16 PM
Thanks, Randy!
Would you happen to know off hand what the size of the wheel nut is?
Randy
randywebb 05-20-2005 05:30 PM
No, I have a '73. But it's big - maybe it is on the Pelican parts diagram in the catalog? If you are dying to work on it this weekend and can't find it, re-post by Sat am and I'll look in the copy of the PET (something else worth your $15).
Want to change the title of this thread so folks can find it easier with the search function?
Best, - Randy
rcecale 05-20-2005 05:45 PM
Randy,
Changing the name would be a great idea. Perhaps something like "Constant Velocity (CV) Joint Replacement"? Moderators????
I'd love to work on this over the weekend. Any info you can provide will be greatly appreciated. I check-in here several times through the day, every day, just to keep up with everything.
As it stands now, I have two threads on the tranny flange that need to be chased. I'll probably end up doing them all, just because. If I can get the axles off too, that would be great.
Glenn at Pelican said my order should be here in 4 - 5 days, so that gives me a week to get everything apart and cleaned up. Hopefully I can catch them first thing in the AM, before they ship anything. Think I'll be going with two new axles, rather than the kits I ordered.
Thanks, again!
Randy
rcecale 05-20-2005 05:50 PM
Found this article during my searches. Just might come in handy.
Remove the cotter pin (non Carrera) and the axle nut. On a non Carrera car you'll be OK with 1/2" drive breaker bar and socket (30mm) but on a Carrera you'll need 3/4" drive (and 32mm socket) because of greater torque on the nut.
Randy
Grady Clay 05-20-2005 07:25 PM
Randy,
You might do a price comparison between the Carrera axle with the friction welded stub axle and the Turbo axle that bolts onto a separate stub axle. I think the latter is more serviceable in the long run. The issue is cost difference.
Unless I’m missing something, all you really need is four boot kits, Molly grease, 12 new bolts and washers, and one good used 108 mm end cap.
The docs had me most of the afternoon so I am still a little goofy. I’ll look up part numbers in the morning.
The good news of the day is I found another stash of Porsche Factory “Service Information Technik” booklets. My goal is to find copies of every one that was printed. I’m getting close.
Best,
Grady
rcecale 05-20-2005 07:39 PM
Hey, Grady! Hope you're feelin better real soon! The doc's can really put a whammy on ya in the name of making ya better! I really appreciate your chiming in here. Now more than ever.
I'll talk with Pelican in the morning and get some part numbers and prices so I can make a comparison between the axles. I have some windows I need to install in our breakfast room tomorrow and then a wedding tomorrow evening, so I won't be able to do much work on this until Sunday...the lawn can wait. :)
Once I get the axles out, I'll be able to make a better determnation as to what I need. Uh....actually, how 'bout I post some pics and you guys can make that determination for me. :D If I can get away with just the boot kits, that would be great! I'll just stick with the list I posted earlier....kits, bolts, schnorrs and moon clips. Gonna have to change my order anyway, so I'll cancel the one I've got and re-order once I've got a better assessment.
Thanks again, Grady! Be well!
Randy
randywebb 05-20-2005 07:48 PM
Is this what you need re axle nut?
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_suspen_pg12.htm#item47
A-332-806-00
rcecale 05-20-2005 08:01 PM
Looks like the nut I'll have to remove to get the axles off. Thanks Randy! According to that article in the link I found, it should be a 32mm. I believe I have one of those from when I tore apart my tranny last year.
Thanks!!!
Randy
Grady Clay 05-21-2005 06:13 AM
Randy,
Confirm a few things for me:
1) What is the Type Number of your transmission? 915/72 or 915/73?
2) Was there was an end cap on the inboard CV joint that didn’t come loose?
3) Was there no gasket between the CV joint and the transmission flange? Is it a flat surface without a step for the gasket?
4) What is the length of the “cheese head” bolt (socket head cap screw)? That dimension is measured from under the head of the bolt to the end of the threaded end.
5) Does the bolt diameter measures nominal 10 mm?
Your situation illustrates how careful you must be to get the right set of pieces. There is a mid-year change in ’86. The early version (G15.69/70) has a CV gasket but no end cap. The later version (G15.72/73) has an end cap but no gasket.
I think I have you the right illustrations and part numbers posting soon – the best I can.
Best,
Grady
rcecale 05-21-2005 08:14 AM
Originally posted by Grady Clay
Randy,
The tranny is a 915/73.
2) Was there was an end cap on the inboard CV joint that didn’t come loose?[/QUOTE]
Yes. The end-cap on the axle that did not come loose is still intact. (See pic below) The axle that disconnected lost it's end-cap. To get it home, I connected it back, without the end cap. There is now a spray of grease I need to clean up underneath the car. :(
3) Was there no gasket between the CV joint and the transmission flange? Is it a flat surface without a step for the gasket?[/QUOTE]
There is/was no gasket between the CV joint and the flange on the passenger side. The driver's side is/was presumably the same.
http://forums.pelicanparts.com/uploa...1116691755.jpg
4) What is the length of the “cheese head” bolt (socket head cap screw)? That dimension is measured from under the head of the bolt to the end of the threaded end.[/QUOTE]
The shank is right at 50mm. (Not 52mm)
5) Does the bolt diameter measures nominal 10 mm?[/QUOTE]
The unthreaded part of the shank is 10mm in diameter.
Thanks, Grady!
Randy
Jack Olsen 05-21-2005 09:42 AM
Note: I changed the title of the thread.
rcecale 05-21-2005 09:56 AM
Thanks Jack!
Randy
Joeaksa 05-21-2005 10:21 AM
Excellent thread. Everyday I learn something its a good day!
JoeA
Grady Clay 05-21-2005 10:25 AM
Randy,
Here is a diagram of the ’86 parts:
IMAGE: Axle86Carrera01
http://forums.pelicanparts.com/uploa...1116698740.jpg"
(C) Dr. Ing. h.c. F. Porsche A.G.
The big issue here is the mid-year change that left out the
previously used CV joint gasket #13 (930.332.297.00) and
replaces it with an end-cap cover #19 (928.332.267.01). When
this change was made it was necessary to also change the stub
axle #3 (from 930.332.232.00 to 930.332.232.04) in order to
eliminate the step that received the gasket. On the axle
assemblies (911.332.024.14) that use the friction-welded outer
CV joint there wasn’t any change at the outboard end. The CV
flange at the transmission also changed (from 930.332.209.03 to
930.332.209.05) in order to eliminate the step that received the
gasket. These changes occurred with the change from
G15.69/70 (transmission 915/69 or 915/70) to G15.72/73
(transmission 915/72 or 915/73).
From what I can tell, your ’86 has the later configuration.
It appears you could use the repair sets #18 (928.332.924.02)
for the inboard ends of the axles. I don’t think you can use
repair sets #11 (923.332.037.00) because it fits the 100 mm CV
joints. Use #18 for the outboard ends and slide the parts down
the axle shaft while the inboard CV is removed. You end up with
two extra #19 end-caps.
You should disassemble and carefully inspect the CV joint that
came loose. Keep all the parts in their same original position. It
is possible that the parts (particularly the cage) were damaged
as the axle flailed about. If damaged, you will need a new CV
joint #5 (930.332.034.00). All the CV joints will benefit from
careful cleaning and new molly grease. I notice the quantity of
grease specified changed from 90 g to 100 g in ’87 with no other
changes to the late ’86 axle assembly.
Note: if the boot #10 and the joint flange #9 aren’t in place, it is
possible to get enough angle on the CV joint for the balls to pop
out and the joint disassemble. It may be possible to get
sufficient angle even with the boot and flange in place.
You should carefully clean the internal splines in the hub (#1)
with a brass wire “tooth brush.” You should similarly clean the
external splines and threads on the stub axle. Coat everything
with WD-40. Just prior to assembling the axle into the hub,
make sure the contact surfaces on the inboard end of the hub
and outboard end of the stub axle are perfectly clean. Don’t
drag any dirt or grit in there as you put the axle assembly in the
hub.
One thing I haven’t figured out is the CV bolt specified for use
with the gasket is M10x60 (900.067.118.01) and the bolt
specified for use with the end cap is M10x50 (900.067.123.01).
That is a big difference! Is this a typo in PET? Is there
something that different in the stub axles and transmission
flanges? The critical issue is when all is said and done that the
bolt penetrates the flange sufficiently.
Note that PET doesn’t specify a Schnorr washer. Be sure and use
them anyway. Remember, the raised ID goes under the head of
the bolt.
Best,
Grady
rcecale 05-21-2005 11:19 AM
Thanks Grady!
To coin a phrase VaSteve has used in the past...You, sir, are the Bomb-digity-om!!!! :D
Heading to a wedding this evening. Printing this info so I can read it and absorb while I'm there. Formal gatherings and me are pretty much like water and oil! ;)
Randy
Grady Clay 05-22-2005 05:04 AM
Experiment:
Was 32K .jpg in above post.
Trying 800x919 = 114K .jpg (about as large as Pelican will accept).
http://forums.pelicanparts.com/uploa...1116766559.jpg "
Best,
Grady
randywebb 05-22-2005 09:42 AM
you want a helper for that big nut - don't let the socket get tilted...
And - Grady - what is the function of the cover 928.xxx? I've always wondered if I should add it to my older CV setup.
Grady Clay 05-22-2005 12:33 PM
Randy,
I think there are several reasons:
First I think Lobro marketed it to Porsche as “Everyone else is using it – MB, Audi, VW, BMW.” I first saw end-caps on the CVs on a McLaren CanAm car in the late ‘60s or early ‘70s.
Second, it is easier to assemble during the manufacturing of the car. No juggling of the gasket while trying to get six bolts started.
Third is probably the contamination of the bolt threads with CV grease. I can’t imagine PAG being able to assemble the earlier axles and keep the bolt threads and clamped surfaces free from moly grease.
I’ll bet the end-cap provides a better grease seal than the gasket. Porsche has gone to great lengths to reduce the “leaks oil & grease” image. No one likes to pull in with their $80K++ and everyone downwind scatters. I think there are some German federal regulations on leakage of anything.
In 09/84 Porsche published the reason as:
“The CV joints of drive shafts for 6 and 8 cylinder engines have been standardized.
“The CV joint diameter of 911 Carrera has been changed from 100 to 108 mm (as already for 928 S/911 Turbo and 911 Carrera Turbo Look). Change does not apply to early U.S. production. An end cap is pressed on for CV joint sealing. The formerly applied seal is omitted. The recess required for this flat seal in the CV joint flange (transmission end) and drive shaft (wheel end) is also omitted.”
Part of my research next week is to see if Lobro put some sealant between the pressed on tin pieces and the CV joint.
Yes, if I were specifying a 911, it would use the 930.332.037.04 drive shaft (axle assembly) that has the end caps, the 930.332.232.04 stub axle, the 930.332.209.05 CV flange at the transmission, the (moon) plates) 911.332.191.00, M10 Schnorr lock washers, and slightly longer M10x52 than standard 900.067.123.01 M10x50 12.9 CV bolts (cheese-head screws).
Best,
Grady
rcecale 05-23-2005 05:11 AM
Unfortunately I wasn't able to do anything with my car yesterday. Home improvement chores got in the way again. :(
Checking out the e-mail I received from our host, it looks as though the parts I ordered Friday are on the way. I'll call today and see about making changes anyway. Thinking I should have waitied until I had the axles apart to see exactly what I had before placing my order.
Well, I still have time before anything arrives, so I'll still work on getting my axles off and then get some pics. this is getting really interesting.
Grady, Randy, really appreciate all your assistance with this.
Randy
rcecale 05-23-2005 06:43 PM
Rats! This stinks!
Finalyy have some time to get back to work on these axles, and find I have NO 32mm socket. Gonna have to wait for tomorrow. Called a buddy from work who said he'll bring it in. So, maybe tomorrow I'll have more than just these 4 pics...
http://forums.pelicanparts.com/uploa...1116902537.jpg
Now THAT'S a spacer! :)
http://forums.pelicanparts.com/uploa...1116902553.jpg
http://forums.pelicanparts.com/uploa...1116902571.jpg
http://forums.pelicanparts.com/uploa...1116902589.jpg
Looks like the 32mm nut is P/N 900-910-093-02, the self-locking nut. I think I already know the answer to this, but what are your feelings about re-using this nut?
Randy
randywebb 05-23-2005 09:31 PM
I wouldn't re-use a self-locker - kinda depends on the the locking feature. Jim Sims can best advise you if you tell him about the nut. But, why not just play it safe...
"Home improvement chores got in the way again"
- see if you slept in your car, you wouldn't have that problem
(BTW, my eyes are still recovering from the bleach mixture I used 12 hrs ago to kill mold so I could paint the house).
rcecale 05-24-2005 01:45 AM
Haven't you seen this thread???? ;)
It just makes sense to replace the nut. Home Improvement chores would be the least of my worries of that thing were to back off of there. I'll add them to the list for round 2 of parts ordering.
Randy
Fishcop 05-24-2005 03:52 AM
Randy, double check the nut size... I've got my hubs apart at the moment for a bering replacement and my nut is definitely 30mm (but it is a much older car - 1969).
Cheers
rcecale 05-24-2005 04:37 AM
John,
I'll take another look with my 30mm. I tried that last night but it seemed the 30mm was just spinning as though it wouldn't go all the way onto the nut.
I've got my buddy's 32mm socket right here, so either way, I should have it apart this evening.
Randy
randywebb 05-24-2005 12:24 PM
Huh - thx for the link. So, if I succeed, it proves I am "dumber" than a retired marine?? I better check this out with some other people I know with hard heads and weathered necks...
rcecale 05-24-2005 04:48 PM
It takes a whole lot of effort to be THAT dumb, Randy! For guys like me, dumbness is second nature! :)
For instance, I was able to get the axle nut off, after a marathon session with my impact wrench. Popped the axle loose and it started sliding out from it's little hole and BAM! Now it seems the shock absorber is in the way.
Okay, sould be easy enough. Just remove the lower shock bolt and swing the shock out of the way, right? Right? Or, is there something I'm not seeing?
I realize when the shock bolt comes out, the rest of the tire suspension assembly is gonna wanna drop down, right? (I really hate not know the correct nomenclature for these parts. I guess this is where that Bentley's would come in handy.)
Just how heavy is this stuff? I have a brick up underneath the brake disk to support it, but I'd hate to remove that bolt and subsequently crush that brick!
Anything else I should be wary of?
Thanks!
Randy, I hope the eyes are feeling better!
Randy
edit: Oh, almost forgot. The Axle Nut? Definitely a 32mm. 30mm was just too small.
randywebb 05-24-2005 05:00 PM
You got the joke (I guess). Not much fear factor to a pip squeak dictator if you tell him a bunch of intellectual guys are sitting off his coast playing chess .... No comment on tactical innovation ...
Be wary of the brick - I'd put a block of wood under there ASAP. Concrete blocks (& bricks) will fail catastrophically in compression. I know a pic of you bench pressing a 911 will look good to your buddies, but only if it is taken in the first minute or so...
Places like recycle centers, wood treatment plants, etc. will have culls or seconds -- usually the ends off of something they didn't want. I have a nice collection gathered that way - a short 4x4 or 6x6 will be fine.
Well, let eh saga continue...
rcecale 05-24-2005 05:14 PM
Always ready for a good joke! I can take it! ;)
Good thinking, about the brick. Maybe I'll go raid the firewood pile and see if I can't locate a suitable substitute. May have a landscaping timber I can cut to fit.
Just how heavy will those parts be? Is that the Swing Arm...the Trailing Arm...? Enquiring minds are dying to know! Will it be one of those things I can muscle into place with one arm while positioning the bolt with the other. (Keep in mind, I've never been able to bench-press my P-car...not even for a few seconds!!! :eek: )
Randy
rcecale 05-24-2005 08:09 PM
Well, I've never claimed I was the sharpest tool in the shed. Pretty much wasted another evening trying to figure out a way to go forward with removing the shock bolt. Was just about ready to call it a day and turn in when it dawned on me. How bout using the jack underneath the wheel brake and lift up on it, releiving some of the weight from the shock bolt. That way, when the bolt comes out, I can lower the arm assembly as slowly and controlled as I want to. It worked on F/A-18s like that...jack under the wing for support, then a wheel jack under the axle lever. Releive weight/pressure and the shock pins came right out.
Any issues with doing it this way I should know of?
Randy
