Concavity of Schnorr washers is with dome ( smaller diameter) under head........
The following is a post for thread:
“Two CV Joint Questions” http://forums.pelicanparts.com/porsche-911-technical-forum/474083-two-cv-joint-questions.html I’m putting it here to help add to this important thread. GUYS, Slow down. Keep in mind, the driving torque through the axle is not transmitted through the CV joint bolts. The tight bolts provide a clamping force across the junction between the CV joint and the flange. The sum of the forces provided by the four or six M8 or M10 bolts is this clamping force. This clamping force provides the shear stiction in rotation across the interface between the CV joint and the flange. So long as there is enough force to prevent the CV joint from ever moving relative to the flange – there isn’t a problem. The issue comes when once, under some circumstance, the CV joint slips relative to the flange. When that happens, it tends to loosen the bolt’s clamping force. (There are other things going on but this is the ‘big deal’.) Additionally the bolts can rotate, becoming looser. As this progresses, things can “go to hell in a hand basket” quickly. The correct method is to torque the bolts to spec dry. This is best done with new bolts and new Schnorr washers. If your bolts are in good condition, including wrenching feature, they can be reused. The bolts ABSOLUTEL need to be re-torqued after a hundred miles or so. Re-torquing is a wise part of annual inspection. Some like safety wire. This is OK after you have re-torqued at 100 mi. This is a pia for regular checking. If you want to use an ‘inspection mark’, a dab of nail polish over the junction of the bolt head, Schnorr washer and ‘moon plate’ works well. If a bolt has loosened enough for a Sharpie mark to show, failure is immanent. Loctite is counter-productive as your re-torque must break the Loctite bond to regain the clamping force. If your CV joint uses a gasket, it is absolutely necessary to insure the gasket is not installed with any bit between the mating surfaces of the CV joint and flange. Having a pinched gasket will lead to a CV joint coming loose. Most Factory gaskets have one side ‘sticky’ to attach to the flange or CV joint. If you have gaskets without a sticky side, use contact cement and glue one side to the flange or CV joint that has the gasket recess. Do not glue both sides. The mating surfaces of the face of the CV joint and the face of the flange must be clean, dry, without oil or grease and without any raised damage. Slight dents below the surface will not significantly impair the connection. The issue of installing bolts dry is difficult with grease everywhere. I have sets of old (slightly longer) bolts that I have cut off the bolt heads. Where the head was is tapered slightly and has a screwdriver slot. I hand thread these into the flange and use them as guides to get the CV joint onto the flange without getting grease where I don’t want it. Once the CV joint is in place, I remove one of the guide pins and install an old CV joint bolt and used Schnorr washer. I repeat on the opposite side of the CV joint. I then draw-up these two bolts so the CV joint is flush with the flange. If I haven’t gotten grease on unintended surfaces I proceed. If I need, this is an easy step to repeat. Once I have all four or six bolts snug, I then torque them to spec. Then, one-at-a-time, I replace each bolt in turn with a new bolt and new Schnorr washer. I torque to spec each one as it is installed. When complete, I re-torque the entire CV joint. If you feel at the end that you have grease on bolt threads, it is reasonable to use ‘Brake Clean’, a suitable size ‘test-tube’ brush and compressed air to clean them. This is best done when you install the new bolts and new Schnorr safety lock washers. ABSOLUTELY re-torque after a hundred miles or so. The life you save may be your Porsche’s. Best, Grady |
Timely!
Thanks Grady. |
Thanks Grady,
I will be rebuilding my CV joints next week and your help is very timely indeed! Are you joining us for the run to Colorado Springs this weekend? |
Grady,
Have read all 15 pages of this thread, and have received quite an education on CVs and axles! My problem is, I have a set of '86 Carrera swing arms (complete w/108mm CV axles), that I want to put into my '80SC (has 3.6 transplant). I have an '84 915/70/LSD transaxle w/the 100mm output flanges. My dilemma is locating the 108mm output flanges (fig 2) to fit the "end cap" type CVs. Just can't seem to find them, and our host shows them at $550 each, ouch! Would it be possible to bolt the "endcap" CVs to the 108mm "gasket type" flanges (fig 1)(if I can find them!), or would there be clearance/interference problems? HELP!! Thanks, Grant http://forums.pelicanparts.com/uploa...1247839722.jpg |
CV Joint Bolts
I saw this thread over at Rennlist.
Group Buy (ACTIVE): Stage 8 locking CV bolts, Round 2 - Rennlist Discussion Forums Anyone have any thoughts? |
I'll go look.
Recovering from shoveling snow, 75F yesterday. Aah Colorado. EDIT Interisting. I'll order a set and see for myself. Best, Grady |
Earerly awaiting Grady review and response!!!!
http://forums.pelicanparts.com/porsche-911-technical-forum/531802-stage8-locking-cv-bolts-all-911-912-a.html |
Just my 2 cents:
On a 930 there are neither moons nor Schnorr washers... |
Thanks Grady!!
My 930 CV came loose last year and I never re-torqued it. I'll be doing that before I drive it any more!! |
So I am electing to use Schnoor Washers (aka Disc Springs / Serrated Safety Washers) even though my car is an '84 and did not have them OR moon plates. I got the washers in 1 day (much to my surprise) from McMaster-Carr.
And now some possibly dumb questions: 1) They are concave - so which way do they go on? CV ) Bolt or CV ( Bolt ? 2) And are the standard bolts long enough to accommodate these washers? I would expect so since they are only a mm thick or so. Thanks -Jonathan |
1. different boot/ flanges have different thickness
when i rebuilt four CVs on my 84, two years ago, I bought less expensive boot/flange kit from the host. Recently one of the boot gave up after only two years, 8,000 miles, and this time i bought more expensive boot/flange kit. I noticed that when I installed the new boot/flange, the end of the bolt sticks out more, say 3-4mm at the transmission flange, while the use of less expensive boot/flange makes the bolt end near flash to the flange thread hole. So, if you bought these more expensive boot/flange kit, you are likely to have more bolt slack to accommodate the schnorr washer. 2. schnorr washer and moon plate for 84 my car, 84, did not come with any washer nor moon plates. when i did the boot/flange replacement, few days later, i saw the bolts come loose! I torqued them quite securely but still, they came out. I was at a track day few days before and it shook me when i thought about all the bolts come loose at the track. So, I went to order the M8 schnorr washers at mcmaster-carr. I had a hard time finding porsche p/n for a moon plate for M8 100mm CV, but I saw my friend's Audi 4000 up on the lift and found out the car had M8 100mm CV with nice moon plates. Audi part quoted for $7.50 a piece. Doing a little more search in the part wholesale database, found out vw rabbit uses M8 100mm and they had several suppliers listed with different price points. I naturally went for the one from empi (p/n 875081) which was $1.50 a piece, which fit perfectly on my CV. http://forums.pelicanparts.com/porsche-911-technical-forum/293582-m8-schnorr-safety-washers-p-n-cv-thing.html#post5388505 I just did another track day with this setup and the bolts are in place. The washers and the plates are doing their job. Now, I could do insert the washers and the moon plates because I had more slack at the bolts from the expensive boot/flange I bought. For the other boot/flange, I do not have any slack at the bolt, so I'd need to get longer bolts. Three other CVs have bolts securely in place and I'm not touching it until when I had to detach them from the flanges. When I did, I'd definitely go get additional moon plates and install with schnorr... 3. schnorr orientation i don't have the vocabularies to explain it but I know the orientation. someone please chime in... you might be able to see it in the pic i posted in the linked thread above. |
Thanks for the details - glad I got the Schnoor washers.
I actually asked this on the bottom of the thread you referenced.... What do the moon plates do? And why only 1 per CV Joint? |
3 moon plates per CV, 1 for 2 bolts.
the pic i posted was taken right after I did the first two bolts. at the end, i had all 6 bolts using moon plates. the purpose of having moon plates is to spread the load over greater surface area (you are talking to a non-technical, worse, non-native english speaking person) so that the bolt head does not crush the tin of the flange resulting in getting the bolts loose over time. |
Understood - thanks. I was referring to the picture - but now I understand that was an "in progress" shot.
Any chance you have the link to the VW moon plates you purchased? Can't find them via google..... or anywhere for that matter. The only link on the web to 875081 is your post and what I think might be your japanese website? |
yes, indeed, i dumped tons of information down on to my website but they are all in the most useful language (at least for me...ha ha...). ;-)
no, my website does not give you good info for the vw part I bought, either. i bought them at the local Discount Import Parts. I walked in with the part number on my note. I obtained the part number from an online part catalog my friend's german car repair shop uses. we searched for the part for vw rabbit. should give you several options and for me it just happens that they listed one from EMPI. I'll be at the shop tomorrow and will get you more info on part numbers from other manufacturers than EMPI. |
Thanks! I'll keep and out for an update.
So what happened to the 930 and the M3? You have had / have a nice collection. |
we sort of forgot how we ended up with that part number so we called vw dealership.
asked for lock plates for 100mm cv, and they said 84 rabbit, 91 golf gti used 100mm. and the part number given was 1J0 407 357 A. we also know that 84 audi 4000 quattro front axle uses 100mm cv and the part number for that is 803 407 357. we can also find in empi's website the part, and probably this is what i bought. EMPIUS.COM : 2010 Catalog, Page 367 - All New Complete Drive Axles the part that says 100mm. #87-5081-0 hope this helps. (typing this from the shop computer. will be here for the next few minutes...may be able to address questions if i capture before i take off. ;-) ) |
Its all a bit of a mission isn't it. Mine is going OK except the M8 50mm bolts I was supplied (they are 50mm) seem to be about 5mm short. They certainly don't extend by a thread or 2. Will they be OK or should I buy some longer ones?
It is a mission - seems strangely more complicated then I expected.
As far as the short bolts - seems that the consensus is that you don't want to risk the CVs coming out - so I would investigate the 55mm bolts. Other people indicated that the height of the metal in the boots can be higher in various versions - which would eat up a few mm. Also are you using the spring washers and moon plates? Not sure what I can offer here - but am curious about the above. I will be putting my new CVs, new boots, new washers together in the next few days and am curious if I will have the same problem. I am electing to leave out he moon plates (at least for now) as my car did not have moon plates or washers. I did buy the washers and plan to use. |
Thanks for that...I went and purchased 55mm long bolts. These are a perfect fit. I have used new washers, no moon plates. Alaways better to be safe than sorry.
The CV part of the rebuild was straight forward, thanks to the advise here. The rear wheel bearing replacement presented a few more challenges but the freezer and heat gun are the secrets! |
can't recall, are these things high strength bolts, 10.9 ??
Outboard CV joint removal
I have a '90 C2 - 964 that is in need of a new wheel bearing. After I removed the axle, I discovered one of the dust boots is torn. So, I removed the inboard CV joint but I cannot figure out the outboard CV joint. Is the splined shaft that fits into the hub pressed onto the axle somehow? If so, how is it removed. I have looked thru the posts on this but cannot find any detail on removed this splined shaft so I can get to the circlip on that side.
hello , I'm sorry for the noob question but this clunk is driving me insane !!! :(
the sound appears when going in reverse or starting from full stop and it appears when I lift off the gas pedal or doing a right 90 degree turn . I made 2 vids of the noise , I think it could be the CV , but there's no play at all YouTube - BMW E36 Rear End Noise , CLUNK YouTube - E36 driveshat U Joint thanks again for the much appreciated help ! :) |
I am installing new rear wheel bearings soon, So i will be taking the shafts out anyway. Looking at my boots, I have no clamps on the smaller ends of them I dont sense anything wrong with the car or CV's, other than a kind of clunk/shudder when i lift off the gas at high rpm/accelerating, which is kind of normal for a manual car. Is it a problem that i have no clamps on the smaller ends of the boots? Can I just put some hose clamps of them and call it a day since the CVs seem fine? I dont know if mine are bad...but they probably are in a 30 year old car...
Hey guys,
Can you clarify please where grease seals were used on 68 year M8 bolts? http://forums.pelicanparts.com/uploads5/MVC+015S1117330165.jpg Thank you. -y |
An update -- I see a lot of interest in drilling the heads of the fasteners and using safety wire...
Safety wire is not needed if the correct fasteners are installed and installed properly. More importantly, safety wire will NOT maintain the correct force on the faces of the CV assemblies. It is this force that transmits the torque from the engine to the wheels. The cap screws on the CV assemblies are in tension (axial direction) and that tension creates the force to transmit the torque of the engine to the wheels. If the cap screw loosens but is held in place by safety wire it will be loaded in shear, which it is not designed to take. The cap screws will then be highly likely to break ("shear off") and you will be in just as bad a situation as if they had fallen out all the way. The only advantage is that you might hear a noise from the loosened assembly before the bolts break. So my view is to NOT depend on safety wire to compensate for incorrect installation procedures. |
Hello,
For the 100MM CVs on my '84 were installed with 8MM x 50MM hex head bolts. I installed some new Lobros, new boots and bolts, promptly came loose. Removed again, replaced gaskets, cleaned all grease out of the CVs. Cleaned every surface with brake cleaner, then an acetone wipe prior to DRY assembly. Dry bolt up followed with brake cleaned assembly bolts. Installed new 8 x 50MM hex bolts with Loctite262, torqued to 33lbft. Injected new grease with grease gun and needle through the axle opening, into every ball groove and all over the inner joint area, almost 4oz per joint. Still as nervous as a turkey on the 24th! Internet rummaging yielded many resources. I had ordered Schnoor washers from our host, got a bag full of washers that start with a 999 part number and looked to be for 10MM bolts, too big! Went to the old internets standby and found a metric hardware retailer and ordered 8MM x55MM 12.9 black phosphate bolts, 8MM Schnoor washers, and from another retailer( TORQUE DISTRIBUTION WASHER [87-5081-0] - $1.75 : Vwbugworld, World Of Vintage Volkswagen ), funny moon plate washers for 100MM joints. I think after hours of reading this forum, I applaud Grady and all the other posters who stretched their brains and bloodied their knuckles and shared their vast knowledge with the rest of us! The VW number to search the Internet is 875081, lots of options. Hardware:https://www.belmetric.com/ |
Update!
After endless OCD driven research on locking washers I decided to use Nord-Lock NL8 locking washer system along with new black phosphate coated bolts. When I removed the old bolts one at a time and replaced them with the new bolts and washers, I noted a reduced torque to remove the old bolts. I posted here about my research: http://forums.pelicanparts.com/porsche-911-technical-forum/731514-all-about-nuts-bolts.html I will follow up after a bit. |
ClickClickBoom - I have an 80 911 SC that originally had the 8X50 on the CV's with no Washers or moon plates on it. After reading through all this and other posts, I am looking to get the longer bolts as well.... the 8X55's... what's the thread pitch on those? 1.25?
Thanks for the links to the moon plates, bolts and Schnoor washers. I just ordered 12 plates from VW world..... 6 for the inner, and I will have the extra 6 for the outer when I replace those joints.... |
I am about to do this job, I have all new bolts 8x50mm. The OEM setup on the SC was bolts with no washers at all. I have found a place to get M8 Schnorr washers, if I add these will the 50mm bolts be long enough? From what I have read so far I gather that increasing to 55mm bolts is only necessary if adding the Moon plates (which originally in 82 were only installed from the factory on the Sportmatic cars).
Right?? |
Nick, I added the M10 Schnoor's on the 8X50 bolts, just to get everything tightened.... (reordering the correct sized washers tomorrow). That said, it looks like with a washer, the bolt is about 1.5mm short of flush.
I had the same thoughts.... but then I read the posts by Grady and the clamping forces necessary to make it not shear or come loose... I ended up figuring $50 was better than dealing with the mess...I think the CV mess was the most annoying and slowest part of the entire engine drop, clean, seal and reinstall... the rest was pretty straight forward...
Interesting, I am awaiting new half-shafts with CV's (complete) from Pelican. In the Pelican catalog it says they come with M8x47mm (not 50mm) bolts and to use these bolts. Wonder if the thickness of the replacement CV's is thinner than original? Not sure....will have to see! According to the parts catalog the Sportmatic used 48mm bolts, the standard SC used 50mm and the 930 used 60mm. Not sure where 47mm comes from. |
I saw that too... let me know how that turns out with the 8X47mm's.... might be the flange is thinner and that 50's would hit the tranny.... but I was curious and would be good to get on the ground intel.....
I work with British Specification for fastener on daily basis and God knows where the "47" come from as there is nothing that measure 47mm on these studs :eek::eek::eek: http://forums.pelicanparts.com/uploa...1373586974.jpg |
Thanks for posting that. I'll measure them against the 55mm bolts when the come in.
| All times are GMT -8. The time now is 02:09 AM. |
