911 Sc A/c
Hi ,
I have a 1979 911SC and was wondering if anyones knows how I can install A/C (Its never had any) , Which parts do I need, are there any full kits available with everything I need ?
If anyone can help it would be great !!!
Old 06-04-2005, 04:48 AM
fred cook's Avatar
Cool A/C add on.....
The easiest way would be to find a donor car in a recycling yard and get what you need off of it. For an SC you will need the following parts:
rear condenser
front condenser w/fan and relay
evaporator coil, fan, relay and mounting box
dryer (should use new only)
hoses
console insert w/switches (temp control and fan speed)
compressor w/mounting bracket and belt
double belt crank pulley
miscellaneous mounting clips and brackets
sub harnesses for the wiring.
Installing A/C can be time consuming and aggrevating but is "do-able". The old hoses are probably going to be too stiff and brittle plus you will want the newer barrier type hose anyway. You can buy a new set of hoses for $3-400.00 or buy the bulk hose, cut off the old fittings and have them re-swaged for about $150.00.
Also, get a rotary compressor if possible. The original York type piston compressor is too heavy and vibrates too much. When I replaced the hoses and compressor on my '80SC I used a Sanden 507 which is not a true rotary but is smaller, lighter and runs much smoother. They are available at a very reasonable price. You also need to decide if you are going with R12, R134a or some other refrigerant. I used the R134a and am happy with the results.
Good luck with your "cool" project.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 06-04-2005, 08:10 AM
Brother's Avatar
I can get you the vast majority of this stuff that I pulled off of my SC.
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 06-04-2005, 08:30 AM
I'm looking for some A/C stuff as well, send me a PM
Old 06-04-2005, 08:43 AM
Brother's Avatar
I have everything except the front condensor, evap box, and blower. I would love to offlaod the rest all together. I can also pull out the switches, relays, and wires.
Paul
1972 914 - Sold
Old 06-04-2005, 08:51 AM
FenderGuy's Avatar
Brother if the others dont take some parts i pm you with a request
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 06-04-2005, 09:15 AM
