Virginia Rocks!
VaSteve's Avatar
Porsche Crest Humidity and CIS?
I did a search on those topics and the knowledge base was shallow....
I don't drive my 911 every day.
On Saturday it was hot and humid here. LIke 90 degrees and miserable. Car drove well, about like normal.
Today, it was about 75 (or less) and the humidity was much lower. The car ran great! Strong accelleration - quicker than usual. Maybe I'm just imagining things.
We all know the drill about the 1/8th turn in the summer (I did this a few weeks ago and it was good!) but how about humidity? I realize this is a major pain in the ass for the street, but what do you track nuts do? Do you adjust when you're at the track depending on the conditions when you arrive? And which way would you turn it for high humidity? More lean?
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 06-16-2005, 07:11 PM
strother's Avatar
Unrelated, but I love the Bucky Katt avatar. I love the Porsche hood ornament.
1982 Platinum Metallic 911SC
Old 06-16-2005, 07:22 PM
Crotchety Old Bastard
RarlyL8's Avatar
75* with low humidity packs more air into every stroke than 90* with high humidity.
I lean the CIS out every summer. It lets me know by the rythmic 800 - 1300 rpm idle when warm. The (warm) air is less dense in the summer so you need less fuel to creat the proper ratio. You also get less power. Water vapor (humidity) also displaces air making it less dense.
Old 06-16-2005, 07:47 PM
Designer King
Paulporsche's Avatar
I usually set mine to a point just before the idle starts to fluctuate on a hot humid day. Then it's fine for the rest of the summer until well into the fall.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 06-16-2005, 08:57 PM
