Rebuilding my 3.2 with 156,000 miles.During teardown,got to pulling sensors,switches,etc. from engine.Head temp. sensor is installed into pocket on side of head & has attached wire on sensor.Because of wire,can't use regular deep well socket,b/c of clearance around sensor can't get boxend wrench or open end on it either
Sent heads & cams to EBS with sensor still in.Apparently,they had issue getting it out also.Ruined sensor in process.Oh Well,add $59 to the tab.What is correct tool for this?? Best as I could judge,something like a o2 sensor socket w/ a slot cut out would appear to work but couldn't find one in correct size which is 14mm??Do I need to sacrifice a 14mm deepwell to the cause or anyone know where to find one.Have looked around some,Craftsman,Snap-On,McMaster-Carr etc....No Luck Anyone????? Just talked to Don @ EBS.....all new valves needed....so much for the budget rebuild
"If you think it's gonna cost $1000, ya better budget for $2000." Chris 85 Carrera 3.2(Back on the road after rebuild) 02 Trans Am WS6 95 Eagle Talon 98 Bravada(sold) 07 G5 |
These can probably be purchased from Snap-On, Matco, etc., but for the $$ difference and time expended, I'd suggest a Craftsman 14mm, 6 pt. deep sockect and cut a slot up the side for this project. We use this setup at the shop and it works just fine.
Marc Morrison 1964 356C coupe '89 911 coupe 2008 Honda Accord 2008 Ford Ranger |
Did check the snap-on catalog @ work.Didn't see it in there.Thats ok.Found an older 14mm socket to modify.Thanks for the response.
Chris
I purchased mine from Snap-On....
Here's a pic.
The Fox Carrera |
Thanks for the info everyone!Will be ready when heads return!
Chris
Snap-On part number:
FRXM14
The Fox Carrera |
If you are going to replace the sensor anyway, you can just cut the wire and use a normal socket.
Alan Jackson 77 911S 3.2 |
Alan is right.
Chop wires and use a socket. I did. Ned
Ned NYNA 11 87 Carrera targa 98 BMW 528i 98 Volvo V70 |
I just cut a box end wrench, 14 mm or if you do not have metric, use a 9/16. Cut a slot into the box end to pass the wire through. Works great.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
I'm With CATCA...
I used a 6 point 9/16" deep socket and chop sawed a slot in it stopping just prior to the square drive...
75 911S Coupe 3.4 Twin Plug - ITB - MegaSquirt 84 Carrera Coupe M491 |
all the heads have a sensor hole, so you can use any of them as #3. be careful not to tighten the new one too much. they snap off. then you have to get the threaded part out again.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 06-30-2005 at 11:49 AM.. |
