The Unsettler
stomachmonkey's Avatar
Still wondering what gets wet.
Car won't start AGAIN today.
Cranks fine.
Wires are new, OEM.
Cap was just replaced.
Car stays covered and dry during rain.
Seems to be high humidity related.
Ground straps?
Second suspect, have one of those cone filters, (I know, you don't have to say it, It's coming off this weekend and stock box is going back on)
I've heard that they can get the MAS air sensor gummed up.
Could humidity cause a dirty sensor to prevent the car from starting?
Scott
"I want my two dollars"
"Brandon Won"
Old 07-18-2005, 09:03 AM
Classic DME relay failure.
Joe
Old 07-18-2005, 01:27 PM
Designer King
Paulporsche's Avatar
Check the DME and DME Relay
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-18-2005, 01:30 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
You don't have Clewett wires do you? Do a search for some recent issues with them and moisture if you do.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 07-18-2005, 01:40 PM
The Unsettler
Not the DME relay unless my spare is also bad.
Have a bad DME on the shelf that has not been rebuilt yet.
Last time it was in the car the car ran, ran like crap but ran so I'll try it.
Wires are OEM.
Thanks.
"Brandon Won"
Old 07-18-2005, 02:26 PM
You still might be getting some condensation inside your distributor cap. Might be worth a check.
Joe
Old 07-18-2005, 05:22 PM
