gliderguy's Avatar
Its all about the boot
Well I wanted to say thankyou to anyone who responded to my questions and how fact-filled some of the old threads were. I have been "hunting" down a warm high idle and have found a crack on the backside of my airflow sensor boot. Anyone have one, in good shape, they would like to part with?
Just felt like inserting the pic
Thats me a 3000 feet!!
76 911/2.7/SSI/2in 1out/tensioners/Ice Green Targa
01 Suburban
02 Jeep Liberty
WillsWings Eagle
"As I hug the mountain tops in my hang glider, the only distraction Is looking below at the roads I will hug with my 911 "
Old 07-18-2005, 07:09 PM
gliderguy's Avatar
bump
Are they hard to find used?
01 Suburban
02 Jeep Liberty
WillsWings Eagle
Old 07-18-2005, 07:29 PM
gliderguy's Avatar
bump
no replies?
01 Suburban
02 Jeep Liberty
WillsWings Eagle
Old 07-18-2005, 09:27 PM
as per pn 930 110 358 03
Part Number Search:
Description Part Number Price More Info
Air Flow Sensor Boot, 911 (1975-77)
H-110-358-03 $69.45
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-18-2005, 09:37 PM
Meanwhile, how about sealing the crack with some silcone sealer to see if that's your problem. It might do the trick and since it's hidden in back where you can't see it...might just leave well enough alone.
Otherwise you might be wasting precious time and moolah while the real culprit continues lurking somewhere inside your engine.
Old 07-19-2005, 12:51 PM
gliderguy's Avatar
Thought about that! Wasnt sure if heat would be a issue with sealant. Should be ok?
01 Suburban
02 Jeep Liberty
WillsWings Eagle
Old 07-19-2005, 01:10 PM
I've used it on ignition cable boots to prevent arcing and it gets much hotter on the plug connectors than it would ever get on top of your engine.
Joe
Old 07-19-2005, 03:24 PM
