MBruns for President
JeremyD's Avatar
No Cylinders and heads yet - so I moved on to the intake and put it together in anticipation of cylinders and heads arriving...
New fuel line came out Great!
Old 08-02-2005, 05:36 AM
Will program for food
ghnat's Avatar
What did you use for the new fuel lines?
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 08-02-2005, 05:47 AM
JeremyD's Avatar
Took my old fuel line to Amazon Hose in Tampa - while I waited - no more than 20 minutes - they installed new stainless steel braid, teflon lined hose and cleaned everything up. Best part was they did both fuel lines for around $100.
Here's a better shot
Old 08-02-2005, 06:00 AM
ghnat's Avatar
That is sooo much cheaper than the $600 for new OEM... Can you disconnect them or did they just replace with the same type fittings?
I gotta find a shop like that in Atlanta!
Greg Hnat
98 Jeep Cherokee
Old 08-02-2005, 08:08 AM
JeremyD's Avatar
Replaced with the same style fitting. Piece of cake.
Old 08-02-2005, 08:16 AM
KTL KTL is online now
Schleprock
KTL's Avatar
That's a steal of a deal.
Greg,
Any hydraulic hose shop should be able to set you up. These guys do all kinds of work for heavy machinery like forklifts and construction equipment. Do a local search in your area and i'll bet you find somebody just like Jeremy's Amazon place.
Kevin L
'86 Carrera "Larry"
Old 08-02-2005, 10:09 AM
The oil you used.....
I was wondering what oil you were using in this before the rebuild. Is there something to blame the worn intake valves on?
NF
Old 08-02-2005, 10:55 AM
JeremyD's Avatar
I bought the car with 43,000 miles. It has 57,000 now. I would care to say that it probably happened before my shift - although there seems to be somewhat of a random pattern to worn guides.
My wrench seems to think that some of the lower mileage cars may actually be worse, than those that are excercised on a consistent basis.
I have been pretty religious about oil changes - always castrol GTX - but hoping to move to synthetic after break in.
Old 08-02-2005, 11:03 AM
JeremyD's Avatar
Wife came home with the better digital camera - Should get heads and cylinders back tomorrow and can move this rebuild to high gear. So - you get some better quality pictures - and yes - I did take down the high spots on the intake.
Intake
JE Porn
Old 08-03-2005, 08:21 PM
JeremyD's Avatar
Few more updates - finally got my heads and cylinders back from JB Racing
JEs cleaned up and ready to go
Installed
Air deflectors installed
Heads on.......
The stuff I thought would be hard was not (installing the rings, rings and pistons in cylinders) The stuff I thought would be easy was a b!tch (like installing circlips)
Also - at the worst possible time (installing the cam towers) my Sears torque wrench decides to take a crap. Cost me a a broken stud and basically had to strip the locktite and will have to start again (with a new torque wrench).
Old 08-05-2005, 07:58 PM
Red intake runners
Did you paint or powder coat the intake runners? Fan and Shroud?
If paint what exactly did you use? How did you prep?
It all looks great.
Old 08-05-2005, 08:27 PM
How is the glass hood coming You don't want to close that engine up and not see it. I'll give you a lot of credit for assembling it yourself. Your making me feel guilty for not doing it myself and letting someone else do it. Any past engine building experience? Then again, mine took almost a year to get back.
Old 08-06-2005, 03:48 AM
JeremyD's Avatar
Re: Red intake runners
It all looks great.
Engine fan and shroud have been powdercoated. They taped the ends of the fins first (at my request)
Engine building experience? Sure I built a Triumph Spitfire Engine back in the early 80's not sure that counts...
Old 08-06-2005, 05:01 AM
84CAB's Avatar
Looks great Jeremy. Did you do a "before" dyno? Do you have plans for dyno run after completion?
ELVIS 84 CAB -SOLD
Old 08-06-2005, 05:07 AM
efhughes3's Avatar
Nice work Jeremy! This is gonna' be great.....
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 08-06-2005, 05:15 AM
JeremyD's Avatar
No before... I did a DE at Sebring the day before the engine came out - does that count?
Old 08-06-2005, 05:28 AM
ghnat's Avatar
I hope my engine looks as nice as yours does... Nice job.
Greg Hnat
98 Jeep Cherokee
Old 08-06-2005, 07:05 AM
CarreraCab's Avatar
Looks great Jeremy,
Looking forward to seeing that guy on the road soon. You're attention to detail and cleanliness is very apparent. Looks like you are a natural at this ! Doug
Old 08-06-2005, 07:25 AM
Still Doin Time
asphaltgambler's Avatar
Jeremy, keep pics of the progress coming. Great posting with lots of info!!
Old 08-06-2005, 08:57 AM
Jeff Alton's Avatar
Jeremy, did you measure the CR on your motor?
Looks nice, good work.
Jeff
www.turn3autosport.com
Old 08-06-2005, 09:02 AM
