D idn't E arn I t
Beautiful! Can't wait to see the #'s!
AOC/Hogg 2028 |
MBruns for President
Deck height .92 mm Pistons were less than .5 gram difference - try that with mahles... Quote:
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Great, that is pretty close!
Cheers, Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Doesn't want/need a 3.6L
BTW, nice looking throttle body! Thanks for sharing the progress. Ralph EDIT: Deck height also looks good, what thickness base gasket did you need? .25, .5, 1.00??? |
.25 on the gasket
Got cam towers on - Left one went without a hitch - right one still binds a little - so I will try and retorque - really don't want to have to pull it again (and have to strip all the loctite 574!)
At least it look more like and engine now Ralph - I should be OK with the CR - If I run a really hot track day I will top off with a little race gas - but otherwise we get really decent gas here being so close to the gulfcoast... If I grenade it - I'm sticking in a 3.6 -
More progress - got my cam to stop binding by just retorquing a few bolts - woo woo
A little more progress tonight And I stuck one of the valve covers on just to see how it looks...
OK - little more progress - a little set back too. In my bone head move I switched the cams - hard to time a cam on the wrong side. So finally got that taken care of - and afterwards - even though I tested and redid 3 times - just to make sure I did it right.
So after a little anxiety - I made some big progress and did some buttoning up... Woo woo! (and the cam lines are just finger tightened - I still have a few supports to add)
Great work Jeremy, I'm jealous.
Will program for food
Oh man do I wish I were at your stage of assembly... Looking great!
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
God I feel like I am giving birth...
Jeremy, did you chamfer the heads at all to accept the 98 mm cylinders. I am just looking at mine right now and wondering if that is required of not?
Thanks, Jeff
Nope but I did have them flame ringed - the cylinders I had were flame ringed - so had to have the heads done too.
OK did the piston to cylinder check tonight - plenty of room with the valve pockets on the JE's. Installed the rest of the rocker arms, oil cooler and set all the valves. Not to difficult - getting to the end of the book so that must mean something, right? No suprises - in fact everything is coming together. I see what some people mean about setting the valve clearance by feel -
Anyway - looking like an engine now here she is sleeping...
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 Last edited by JeremyD; 08-15-2005 at 09:52 PM.. |
Author of "101 Projects"
Re: Bling Bling Baby!
![]() -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Re: Re: Bling Bling Baby!
This jack? That's my number 2 jack - I have sentimental attachment to it now... It doesn't really get any work, I just roll it around the car so it feels like it's included... It's the first floor jack I got (with two box tops from cases of Castrol) since you got me started on this adventure... Before hooking up with this board - I didn't even change my own oil - Now look at... and it's all your fault Wayne!
A few more updates =
Go alternator hooked up - front fan belt cover = Engine Shroud and Intake. Still have to torque down the intakes - but wanted to make sure I had everything present and accounted for.
2nd picture
Awesome work Jeremy!
I haven't been around much lately so I must have missed what made you tear it down. |
