Jeff Alton's Avatar
9.8 is probably about the max. A bigger will actually hlp reduce the need for the twin plugging. A custom chip with a little less advance may be required. A lot will depend on how good the gas is where you live.
Jeff
www.turn3autosport.com
Old 08-23-2005, 09:16 AM
MBruns for President
JeremyD's Avatar
Euro is at 10.3 - When I started on this adventure I was told that anything under 10.0 and I would probably be fine (by several sources that have WAY more knowledge than I do). MANY people run the 3.2 euro carreras at 10.3 to 1.
I checked my CR the first time and got right around 9.8 I rechecked (after all this discussion of 9.8 JE's coming in at 10.5 to 1) and the 2nd time filling through the spark plug hole got a 9.7 to 1.
I think twin plugging looks cool - but not sure it's absolutely necessary.
Old 08-23-2005, 09:32 AM
PeteBrown's Avatar
Thanks for the great information.
Pete Brown
'87 911 Coupe
'20 718 GT4
'25 Aviator
'25 Mach E
Old 08-23-2005, 11:39 AM
JeremyD's Avatar
Ok - made some more strides - got it from the stand to the ATV jack. Finished the sheetmetal install. Bits and pieces.
Obligatory engine on the stand picture, cute picture of the kid...
Hopefully this will be knocked out this weekend - depending on Hurricane Kat, of course...
Old 08-25-2005, 07:46 PM
efhughes3's Avatar
Yeehaaaa-getting close!
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 08-25-2005, 07:54 PM
Jeremy,
When you are done can I send my engine to you : ) I am VERY jealous. Amazing job - Tim
2008 M3
2008 Tahoe
2006 BMW X5
1985 911 F Stock - Sold
www.ladamapizzeria.com
Old 08-26-2005, 07:08 AM
JeremyD's Avatar
Thanks Tim - I'll include some goodies for you.... You can borrow my engine stand adapter if you promise to send back with your dad's stuff.
I made some more progress - although I got sidetracked with a CV joint/axel that needed replaced = one thing bad about the 993 brakes on the rear is there is no friggin room for the lower caliper bolt - no problem = made a little tool to get back there.
New CV Joint/Axel
Engine/Tranny/New clutch all together (well, not bolted but mated)
This was piece of work - came apart pretty easily - but had a heck of a time lining up the bell housing and clutch/flywheel etc.... Weltmeister clutch update fit like a champ - in fact almost too well when a dropped a damn f*%$#^ screw into the bell housing - so - did this twice today... Joy Joy! Clutch was easy with the engine out.
Old 08-26-2005, 05:47 PM
efhughes3's Avatar
Man, you're close. My tranny went right back up to the motor, I had my "issues" trying to split them.
Talk to me about the problem on the rear caliper bolt. I'm still waiting for Dave Walsh to send my calipers, he's had some kind of tooling problem-hence the delay, so I'll be faced with mounting in the near future.
Ed Hughes
2015 981 Cayman GTS
Old 08-26-2005, 05:59 PM
JeremyD's Avatar
Well the problem is no room - as in can't get anything to fit -
My solution - cheap 19mm socket that I epoxied in a 8mm bolt and nut
Old 08-26-2005, 06:38 PM
Will program for food
ghnat's Avatar
Jeremy,
That engine and tranny look sooo clean. What did you have done to them to look so good?
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 08-26-2005, 08:03 PM
JeremyD's Avatar
What did I have done to them?? I cleaned the crap out of them - simple green - engine degreaser - three different types of brushes. my fingers are sore just typing this.
Old 08-26-2005, 08:25 PM
JeremyD's Avatar
OK, this is sick - and yes, it's the same tranny and engine...
Before
After
Old 08-26-2005, 09:17 PM
ghnat's Avatar
Well it is a good sickness because both look great!
Greg Hnat
98 Jeep Cherokee
Old 08-27-2005, 07:58 AM
JeremyD's Avatar
Stayed up late last night (more like early this morning) and put the engine in - It's not all the way connected - still have to finish up the B & B oil lines, transmission connection, electric connections. I do have the cv joints connected - motor and transmission mounts, front heat exchangers, starter, clutch slave cylinder, front hard line... I'll try and get everything finished today...
Ready to go in........
It's in!
Underside
Side shot
Old 08-28-2005, 08:05 AM
ghnat's Avatar
Whats that dirty bracket doing on your clean car (pic 3)?
Greg Hnat
98 Jeep Cherokee
Old 08-28-2005, 08:12 AM
JeremyD's Avatar
Ahh the muffler will cover it up...
Old 08-28-2005, 08:14 AM
Still Doin Time
asphaltgambler's Avatar
Can't wait until the test drive!! Please keep the info and pics coming!
Old 08-28-2005, 10:27 AM
You went the same route I was going to go before I found a '97 3.6 from Steve Timmins....
I wish I had had the time [someone else installed the engine] to make the engine and tranny look as good as what you have done! Your engine bay is terrific!
Keep posting!
Was EBS as good to work with as I anticipated they would be? I can't believe how close your engine design is to what I had put together for mine! I traded my old 3.2 for the labor to completely rebuild my suspension [elephant Racing, Rennsport, Bilstein, new master cylinder,
stainless brake lines, pads, Wevo engine mounts, mono balls f+r, tri strut brace, etc.]. It is a different car!
Just wait! You are going to have a GREAT time in your 'New Car'!
It looks soooo GOOD!
Drums
'89 G50 w/ 3.6 V-Ram-now Ca. legal!
FORMER Yosemite Chapter PCA V. P.
Old 08-28-2005, 06:16 PM
JeremyD's Avatar
Thanks drums - I considered going the 3.6 route too - everybody I talked to said this was a good combination - EBS was great - very thorough - Jon kept me up to date. My heads looked like new when they returned.
Old 08-28-2005, 06:26 PM
efhughes3's Avatar
Jeremy: I was waiting for the post where you told us you fired her up today?
Ed Hughes
2015 981 Cayman GTS
Old 08-28-2005, 06:39 PM
