I'm not here.
How does one remove rust from here?
I was wondering if anyone could shed some light on this. It's the area where the parcel shelf meets the left and right corners of the rear. I removed most of the sound deadening material but am wondering if anyone out there has done some work in this spot. I'm sure there's a quick fix.
![]() thanks for the replies...
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?) |
I'm not here.
rust in the rear window/shelf
Sand blast the inside, being careful not to warp the surface metal.
Heat and remove the lead from the outside surfaces. Weld in a patch for the hole(s). Re-lead or fill/blend the low area's. Etch and prime inside and out. Or you could use POR15 on the inside surfaces with the etch and prime on the outside. Bob |
Thread Tools | |
Rate This Thread | |
