Guest
Posts: n/a
You have to push and wiggle it back after the rivets are out. It tends to bind on the threads.
Thanks Mark,
Do you know if I have to buy the whole enchalada ($400+) for the ignition device, or can a lock smith fix the mechanical part? Thanks for the help
Rick '76 Carrera 3.0, track '77 3.2 targa, back home '95 993 C4 M030, SOLD PCA San Diego |
Guest
Posts: n/a
Rick,
I had to replace mine because the interlock for the steering column went wonky. If your prob is in the tumbler, it may be worth trying a locksmith. |
Mark,
Ya thats what I'll do, when I remove the ignition body does it pull out of the steering column? It's kinda hard to see in there upside down.
Guest
Posts: n/a
Yes it pulls out of the column after you get it pushed back from the dash. Good luck with it.
Thanks for the help Mark.
I owe you an R-eola
