RETIRED
Joe Bob's Avatar
Probably ignition switch....
So after kicking Ingo's butt in a drag race, the engine refused to shut down when the key switch was turned off....
Ignition switch going bad? Had to kill the motor by letting out the clutch with the brake on....what say you guys?
2012 ML350 3.0 Turbo Diesel
Old 08-14-2005, 07:24 PM
Mark Wilson
Guest
Posts: n/a
Electrical module on the back of the ignition switch? Pain in the ass to replace for an old fat guy (me). Take the seat out and lay blankies in the floorboard.
Old 08-14-2005, 07:32 PM
RETIRED
Joe Bob's Avatar
Anyway to test it instead of tossing parts at it?
Old 08-14-2005, 07:42 PM
Silveresrty911S's Avatar
WOW!!
Same thing happened to me after I put a For Sale sign on her today. Went out golfing and it stayed in the on mode, had to diconnect the ground on the battery and re-connect to start after playing, Same thing when home.
I thinks it's Karma.......
or it just went bad at the wrong time
Yaaaaa throw some parts at it, that's what I'll do
Rick
Rick
'76 Carrera 3.0, track
'77 3.2 targa, back home
'95 993 C4 M030, SOLD
PCA San Diego
Old 08-14-2005, 07:44 PM
RETIRED
Joe Bob's Avatar
Yeah..it's God hating me for kicking Ingo's butt....did I mention that he was able to see the yellow change on the other light and got a jump on me at the green....had a full car+ lead on me and I still pulled him by fourth gear.........%^B
Old 08-14-2005, 07:47 PM
Ingo SUCKS !!! Blame it on him....
Rick
PCA San Diego
Old 08-14-2005, 07:49 PM
911mot's Avatar
Check stop/tail bulbs are correct too
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Mark Wilson
Guest
Posts: n/a
Just guessing, but, I'd try uscrewing it off the back of the switch housing to get it viewable. There are 2 screws holding it. Gonna take a small, stubby, flat to get to it. Look at some pice on the forum to get orientation. Once you have it out, you'll see a phillips looking receptical on the inside of the module. Use a #2 phillips in the receptical to start and kill the motor. I'd guess that if it keeps running when you kill it, that's your problem.
But as always, I could be full of ****.
Old 08-14-2005, 08:01 PM
walt's Avatar
Possibly using a remote starter might tell you if its the switch or not. If it starts and stops ok, its the ignition switch.
Walt
82SC 3.0
81SC 3.6
Old 08-15-2005, 02:44 AM
What a pain in the arse, I still havn't got to that top screw. I made a flat head driver out of an allen but I can't see it. I took off the break away bolts and she still won't come out. Looks like it's tied to the steering column also. That wasn't in Wayne's 101 book.
Now what? I don't want to give up but 2hrs on this aAny help would be appreciated.
Thanks, Rick
Rick
PCA San Diego
Old 08-16-2005, 08:20 PM
RETIRED
Joe Bob's Avatar
Well...why don't we ask Wayne????
Old 08-16-2005, 08:27 PM
Wayne.....
Anyone else have a trick to get this electrical part of the ignition off the switch?
Rick
PCA San Diego
Old 08-16-2005, 09:26 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I didn't push it 'cause I was afraid that body parts would be flying off your ride. You never know considering they hooked the turn signals to the headlights.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 08-16-2005, 10:23 PM
walt's Avatar
I bought a DeWalt electric screwdriver bit that was the perfect length from Home Depot. You will need to push on it with your finger as you turn the shank with a small wrench. Took a long time but finally got it, also found it helpful to remove the seat. Not a job for the impatient.
Walt
82SC 3.0
81SC 3.6
Old 08-17-2005, 02:47 AM
Thanks Walt,
I'll try that, I've cut down some small screw drivers but they haven't been quite the right size. It's not to bad with the seat in as long as you have a pillow/prop for your head in that upside down position.
Rick
PCA San Diego
Old 08-17-2005, 06:38 AM
Mark Wilson
Guest
Posts: n/a
Rick,
If you're trying the get the entire switch out, it is tied to the column. The is a 13mm lock nut with an allen set screw that holds the column lock boom in place. It's a real PIA to get to, but I completed mine this weekend. Main thing I read was DO NOT back the allen set screw all the way out cuz it's difficult to rethread. Good luck.
Old 08-17-2005, 07:05 AM
911mot's Avatar
My switch went bad - it wont turn all the way to the crank position.
So all I did was purchase the new electrical switch part and plugged it into the loom. Large phillips and I'm good to go.... as long as I don't forget the steering lock
PS did you check the bulbs? electrical issues {Strange}
1984 3.2 Carrera
Old 08-17-2005, 03:24 PM
Well I got the electrical device out and that was not it
It seems the mechanical part of the switch (where the key goes in) is askew somehow. It's either off line or semi worn inside. I put the new one on and it wouldn't even fire the engine. I re-installed the old one and she cranked up fine but would not shut her down..You Biaaatch
I loosened the 13mm lock nut and the allen set screw until it fell out and the entire ignition still will not come out (the breakaway bolts are out).
What the F*#$.
I'm lost, I'm guessing it's going to the shop for the first time for something I can't fix.... I'm bumed because it just came out in the Car Trader today as she's for sale!
Rick
PCA San Diego
Old 08-19-2005, 06:57 PM
Mark Wilson
Guest
Posts: n/a
Did you drill out the 2 rivets on the plate as well?
Old 08-19-2005, 07:01 PM
Crap now ya tell me!!!
The switch seems to move but I can't get it out of the friggen hole.
Rick
PCA San Diego
Old 08-19-2005, 07:05 PM
