Chuck Moreland's Avatar
Originally posted by evill
Chuck, the bushings are the stock rubber ones. It did slide up on the end of the A arm though.
There is still a clue here. The rubber bushings should never have slid off like that.
Is the rubber deteriorated?
Chuck Moreland - elephantracing.com - vonnen.com
Old 08-19-2005, 11:58 AM
evill's Avatar
I'll know for sure when I get it apart, but I would suspect that it is.
Ed
Basically, I'm One Giant Train Wreck.
http://community.webshots.com/user/evill914
Old 08-19-2005, 12:04 PM
evill's Avatar
Originally posted by sammyg2
Ed, if you turbocharged that car it never would have happened.
Is it just me or is anyone else thinking that J.D. sabotaged it to keep you from passing him on the track?
(inside joke, and hoping I'm thinking about the right Ed. Otherwise I'm gonna look real stoopid)
You got the right guy Sammy, it's me.
Actually, I don't think JD had anything to do with this one, but you never really know do ya?
I think my buddy Imcoz may be tryin' to do me in though
Regards,
Ed
Old 08-19-2005, 12:06 PM
evill's Avatar
When I do fix this, what should I do about bushings? I have a brand new set of the street or soft Weltmeisters that i was going to put in. I'm getting the impression that these could eventually cause problems too.
What are the recommended replacements?
The Elephant Racing bronze types?
Ed
Old 08-19-2005, 12:09 PM
Unregistered
sammyg2's Avatar
What should you do? I think it's obvious but I'll give you a hint: 935 tube frame
Old 08-19-2005, 12:29 PM
Imcoz's Avatar
...After my failed attempt at getting that piece of &^%t dc automotive 3 liter to land in your lap, I figured I'd rig the 911 for a hell ride...
Coz
88 911
72 914-6 Vintage Racer
76 914-6 Vintage Racer
Old 08-19-2005, 01:42 PM
Unregistered
sammyg2's Avatar
You guys from Jersey play rough.
Old 08-19-2005, 02:07 PM
evill's Avatar
Hey Rubber Nutz, remember, I'm your ONLY friend.......... and I don't really like you all that much either.
You probably put those things on with your Super Duty 350-ft lb air gun too right?
Come to think of it, the front sway bar drop links fell off it in the first few weeks too. Was that your 1st attempt to do me in?
Eddie
Old 08-19-2005, 02:16 PM
evill's Avatar
Nah... We've been buddies since 1st or 2nd grade.
I was faster than him back then too...
Ed
Old 08-19-2005, 02:17 PM
jyl jyl is online now
jyl's Avatar
Ed
Yes, they are great.
Old 08-19-2005, 04:25 PM
evill's Avatar
Week End Update
Well, i got the front t-bar mount off this weekend. This is the factory pan. There is no accident repair or parts replacement. There is absolutely no rust. The factory body sealer is in tact and still very rubbery after 28 years no less.
I cannot under stand how these 3 nut inserts pulled out. My buddy who I bought the car from said the the very front one was loose when he put the new t-bars in, but he was able to tighten it down.
The metal around all 3 inserts was very clean and shiny and the edges were torn where the insert separated. These look like they are pressed in or pinched over the metal from the factory, not welded.
I drilled out the spot welds and removed the factory brackets from the pan. After cleaning the paint off, I made plates to put on the insides of them, where the nut inserts go to reinforce that area. I welded the reinforcements in and then cut 3/4-in holes with a hole saw to reinstall the nut inserts. I ran a MIG weld around the inside and the out side of the nut inserts. I did a test install and all the bolts line right up with t-bar bracing and tow hook/cover. I will weld them back in tomorrow.
Here are some pics from today.
Ed
Old 08-20-2005, 05:46 PM
evill's Avatar
Repaired
Okay, the repair is complete. I welded the mounts back in, plug welds through the original holes and a few stitch welds on the perimeter. Some seam sealer and paint and you's never know. Took it out for a good floggin', rock dead steady with no issue.
I had checked the passengers side, no signs of stress. I will weld these on the ousides over the winter when I paint the car.
The more I think about it, the more I believe that this damage occured during transport from the West Coast. If the car was chained too tightly or not tightly enough, it may have had a constant tugging on the A-Arm mount for 3k miles. These nut inserts look like the pulled straight down through the metal.
Mo' pics.
Ed
Old 08-21-2005, 03:00 PM
evill's Avatar
Last 2
Old 08-21-2005, 03:03 PM
Driving member
jester911's Avatar
Nice job on the repair.
Glad it turned out okay.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 08-21-2005, 03:05 PM
I'm with Bill
Rick V's Avatar
I recomend you not buy any lottery tickets. I believe you used up all your luck for a while.
Happy to hear you and car ase safe
Old 08-21-2005, 03:52 PM
pa911's Avatar
I've seen that happen once where they used it for a place to tie down on a roll back they winched it down so tight it started to pull them out.
Old 08-21-2005, 04:34 PM
North Coast Cab's Avatar
Nice job on the repair. This happened to a 911 race car earlier in the year and the guy just bought long bolts and mounted a plate on the top. He had a fuel sell so he had easy access.
John
1985.5 944 GTS
Old 08-21-2005, 04:40 PM
