jamesjedi's Avatar
I have not posted a stupid question in a few days....European Racing Headers and fit.
Hi all,
Will 2.7 liter, 1 5/8 European Racing headers fit a 3.2 . Is there any fit concerns, IE; the flange? Is this the best fit?
James
Old 08-19-2005, 03:54 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Re: I have not posted a stupid question in a few days....European Racing Headers and fit.
Originally posted by jamesjedi
Hi all,
James
Not a dumb question IMO, I use George's 1 5/8" OD headers with 2" OD adaptors for a Dansk street muffler on my motor with no fitment issues. What do you mean by flange concerns?
Are you going to be using adaptors/street muffler or straight megaphones out the back?
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 08-19-2005, 05:14 PM
RETIRED
Joe Bob's Avatar
Unless you order them for street muffler use, they come shorter for proper fitting of "zoomies". Most people just use the add on pieces you see in the pics above.
2012 ML350 3.0 Turbo Diesel
Old 08-19-2005, 05:24 PM
Bill Verburg's Avatar
good choice as long as you don't want heat
Bill Verburg
Old 08-19-2005, 05:37 PM
jamesjedi's Avatar
What I am trying to figure out is...can I use the headers from a 2.7 that are 1 5/8 European Racing Headers for my 3.2? Are they identical headers? What I mean by "flange" is - where they bolt to the engine.
They will have megaphones (is that the same as zoomies?). As always, thank you for the insight.
James
RETIRED
Joe Bob's Avatar
Depends on the pipe size...some people use 1.5 to 1 5/8 tubing on 2.7s....I used 1 5/8 on my 3,6...
Old 08-19-2005, 05:39 PM
Yes, the bolt pattern is the same for all 911s thru '94 964.
the Carrera has longer studs, change them or shim the nuts.
1 5/8" D is 1 1/2" ID one step up from SSIs
Bill Verburg
Old 08-19-2005, 05:43 PM
jamesjedi's Avatar
They are 1 5/8 inside diameter. Would it simply bolt on to my 3.2 the same as they did for the 2.7 they were on? Maybe the 2.7 bolts...or exhausts ports are not the same as the 3.2.
James
Old 08-19-2005, 05:45 PM
RETIRED
Joe Bob's Avatar
They fit...the late 3.6s are different....they angled them 180 off...
Old 08-19-2005, 05:46 PM
jamesjedi's Avatar
Excellent! That is what I was hoping to here. Is the engine block the same size?
James
Old 08-19-2005, 05:49 PM
Yes
Bill Verburg
Old 08-19-2005, 06:53 PM
jamesjedi's Avatar
Thanks. That will help a great deal.
James
Old 08-20-2005, 04:44 AM
