Somatic Negative Optimist
Gunter's Avatar
Question Torque method questions
In industrial applications, I rarely came across a situation where dry-torque was required (Like for Titanium)
Accepted procedure was to have a lubricant not only on the threads, but also on the bearing/sliding surfaces like on the flat-washers and underneath the nut.
Of course, on rod bolts, the lubricant is the thread locker.
Wayne, in his Engine-Rebuild-Book, uses what he calls "Nonstatic Torque" meaning steady turning until the torque wrench clicks.
I also remember "Torque value plus an additional segmented turn", like: Torque plus 1/4 turn.
This method of setting the torque, and then tightening an additional amount, was applied under high heat to large-size bolts on turbines.
Where, on a 911-engine, is the "Torque plus ?turn" to be found?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 08-22-2005, 11:18 AM
