Differences between 1974 Carerra RSR's
For my first 911 project, I am considering building a 1974 RSR clone (body and paint important but mechanics and interior not) out a 74+ 911.
From the research I've done thus far it seems like there were different body styles for the 1974 RSR. Some have the wide, vented rear flares and some don't:
http://hobbystage.net/porsche/mouse/
Can anyone shed any light here. I was also wondering if the year 911 to start with made a difference (1974-1989).
Anyone have a documented build up online?
Thanks-
Craig
Old 08-30-2005, 12:07 PM
I just went back and researched a little more and realized the 1974 RSR had the vented flares and 1974 3.0 RS didn't.
I'm wondering what the difference between the bodies of the 1974 RS 3.0 and IROC are? They look similiar.
Craig
Old 08-30-2005, 12:32 PM
Bill Verburg's Avatar
The base RSR's and Carrera 3.0RS had the same sized flares as the 930 i.e 9 & 11"
The vented flares are an additional 2" each i.e 11 & 13"
Bill Verburg
Old 08-30-2005, 12:44 PM
Eric Coffey's Avatar
Originally posted by fastbacker
...I'm wondering what the difference between the bodies of the 1974 RS 3.0 and IROC are? They look similiar.
Craig
Yep, what Bill said. So, the only visual differences would appear to be that IROC cars had completely fiberglass tails and black headlight rings, whereas the 3.0RS's had a rubber lip tail, and body-color headlight rings. Also, the IROC cars had the "Porsche" side script, and the 3.0RS had the "Carrera" side script.
Old 08-30-2005, 12:55 PM
Early_S_Man's Avatar
Porsche Crest
The '74 RSRs used 10.5" & 14" center-lock wheels that would be virtually impossible to get for a replica ... or prohibitably expensive!
The IROC cars were RS 3.0 bodied cars with early-development high-butterfly 3.0 RSR engine of 315 hp output, and 9" & 11" Fuchs from the '73 RSRs. All 15 were sold off by Penske after the first IROC series ended. Most were raced for several seasons ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-30-2005, 12:56 PM
naparsei's Avatar
I think the rear lens treatment was different on the IROC cars vs. the Carrera/RSR. The IROC cars also ran Fuchs. FWIW, the IROC cars originally shipped with a ducktail, but the other wing was added after testing.
'74 Euro Carrera * '64 356SC Coupe
Old 08-30-2005, 01:13 PM
Work in Progress
Rich76_911s's Avatar
There was a thread on here that had some pictures of actual IROC cars. If you find it there could be some good pics for you to go off of. Sorry I cannot help anymore. I will do a search and see if I can find it, doubtful.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 08-30-2005, 01:22 PM
iroc/ RSR
Old 08-30-2005, 01:31 PM
rear iroc with incorrect rear reflector
Old 08-30-2005, 01:34 PM
our interpretation using turbo flares< this car was for sale again recently on e bay
Old 08-30-2005, 01:37 PM
Yep, the IROC center reflector should just be a blank, body color panel with the "Porsche" script.
Old 08-30-2005, 01:43 PM
What would it take to turn a 1976 Turbo body into a 1974 Carerra RS 3.0 (I know the shape of the flares are slightly different)? Is it just the bumpers and tail that are different?
Thank you-
Craig
Old 08-30-2005, 01:45 PM
bumpers, tail, reflector- put a piece of body colored vinyl over it, wheels, rear view mirror
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 08-30-2005, 01:48 PM
Work in Progress
IROC
RS 3.0
RS 3.0 Interior, at least that is how I labeled the pic when I saved it I could be wrong about this one though.
And Finally a little touch of uniqueness that I have an affinity for is an IROC radio delete plate (I think). Though it is not in an IROC in this picture If you find one let me know where you found it because I would be interested.
Rich
Old 08-30-2005, 01:50 PM
Ok here are the flares and wheels and tires;
'73 Carrera 2.7RS(M471 & M472 spec)(flares correspond and are similar to the later SC/Carrera body), old style bumpers in steel, 7 & 9" flares, 6 & 7" wheels(w/7mm spacers rear), 185/70 & 215/60 x15 (street trim)
'73 RSR2.8(M491 spec)(flares correspond and are similar to 930), old style bumpers in f/g, 9 & 11" flares, 9 & 11" wheels, 230/600 & 260/600 x15 tires(race trim)
'74 Carrera 3.0RS(M691spec)(flares correspond and are similar to later 930 body), new style bumpers in f/g, 9 & 11" flares, 8 & 9" wheels, 215/60 & 235/60 x15 tires(street trim)
'74 IROC 3.0(flares correspond and are similar to 930 body), new style bumpers in f/g, 9 & 11" flares, 9 & 11" center lock wheels, 230/600 & 260/600 x15 tires(race trim)
'74 RSR 3.0(flares are 2" wider f/r, leading & trailing vents rear, trailing vents front), new style bumpers in f/g, 11" & 13" flares, mg, 10.5 & 14" center lock wheels(BBS was a cheaper optional wheel), 245/575 & 305/575 x15 tires dry race, 9 & 12" rain wheels
Bill Verburg
Old 08-30-2005, 01:56 PM
bill- iroc cars did not have center lock wheels-
1970 911 Targa "ST"
Old 08-30-2005, 01:58 PM
Right you are, in all the ones I have seen, I was just going through Starkeys 911 R-RS-RSR and quoted him. Should have cought that.
Bill Verburg
Old 08-30-2005, 02:06 PM
What was in place of the reflector on 1974 RS3.0 - was it a metal piece?
Thanks again-
Craig
Old 08-30-2005, 02:20 PM
when i was crusin' the various porsche shops after school back in '75, AIR had a really nicely fabricated aluminum reflector replacement that he gave me. I am not sure, but this could have been what the iroc's used.- It was too nicely made , but not really lighter than the plastic reflector- sure much sturdier!
Whenever we make a replica we either start with a scratched up reflector, prep and paint to match the body- or if easy to match to existing vinyl, we lay bulk sticker material over it , then the Porsche graphic
1970 911 Targa "ST"
Old 08-30-2005, 03:22 PM
lika -dis'
Old 08-30-2005, 03:25 PM
