How many MPG Does your 911 get?
Hey Chaps-
Looks like fuel is going to shot outta control pretty soon, so i thought it this might be of interest for those of us whom aren't doctors, lawyers, and ex-marketing guys.... Maybe this format? 1996/ 993 Coupe/67,000/ 18 MPG Cheers, Capt. Crunch |
1978/ 911 cabriolet/43,000/ ~18 MPG
1978/ Euro 911 Targa /157,000/ ~16 MPG running Chevron 91 Octane
B.T.W. I was told by the dealer to always use premium, but how necessary is this? It might be interesting to know what fuel others use as well as their gas mileage. |
Us in the legal field are price sensitive too :confused:
1980/911 SC Targa/75,000?/15-20 depending on the weight of my right foot:D |
1968/912/9,000 on rebuilt engine (165000 on chasis)/28mpg
use 92 octane underpowerd.. not really, while its not 911 power, its beefed up a tad and is faster than a stock 912, its light as hell, and just as much fun around the twisties as a 911 (probably more fun with the better weight distribution). and it gets good gas milage :D |
78/Euro 911/93,000 miles (10K on a rebuild)/19 mpg
'95 993: 19-20mpg
'82SC: 15+ mpg (a close guess as I never top it up) Edward |
74 Carrera 911/81,000 miles (4K on a rebuild and 2.9 engine upgrade 220hp@7100 RPM) no more than 15 mpg 93 octane (MX. gas)
1983SC/108K/18mpg
1983 / 911SC Cab / 90,000 / 17 MPG
on my '88 targa I got 15-17 around town during the winter and 17-19 during the summer. The highway mileage was 22-24.
My 930 got about 10mpg before I tore it apart. Hopefully EFI will improve that a little. I pulled the R1100S out today and left the truck at home. I plan to ride it to work for a while.
1984 / 911 Cab / 188,000 / 20ish around town if I dont get on it to much...
16+ mpg on the in 5th gear above 3.2k rpm.
Running 2 & 3rd around town would be cheaper if it was towed. |
1978sc/222,500(25k on rebuild)/20mpg
Before tune-up and valve adjust I was getting 16-17mpg. Pays to tune-up. I go 23 mi. one way to work. My Jeep gets 13mpg going downhill with the wind at your back. Guess I'll be driving the 911 more often, poor me:D |
1983 / 911SC Coupe / 127000 / from 27 MPG (highway) to less than 10 MPG (track).
It's a slightly lighened euro model with spoilers. |
1970 911S roughly 12 mpg
1982 / 911 SC Targa / 49,000 mi 23-25mpg Hwy
1970 / 911E / 156.000 mi about 10 mpg ! Car came from sea-level, was running a tad rich at 13%. Had the mfi adjusted, so I suspect my mpg will improve, while I continue to pay more every time I fill up. |
1985/ Carrera Targa/ 155,000 mi/18-20 mpg on premium. Looking at $70 fill ups now.
1985 Carrera Targa/ 26,000 mi/ 18-19 around town hard/ 25-30 highway depending on speeds
1983 911SC Euro Targa, 930/10 motor stock except for SSIs, 161,000 km, 24 mpg highway, 20 around town, during summer.
77S - 22MPG on my recent run from North of Seattle to Portland Raceway for the ALMS. Two people + luggage, etc., mostly 70-80mph cruising with occasional triple-digit motorhome passes.
'73 911T targa with '86 3.2L.... consistantly getting 27mpg. About 75% of my driving is highway miles and I do get on it when I have the opportunity. Can you believe this is my "economy car"!
With gas prices though, I am going to have to start riding the motorcycle more often. |
85 Carrera, about 20 overall on regular.
1987 TurboLook Carrera, completely stock, 91,000 miles, 18-20 in town on 92 octane gas. Gas in NC went up 30 cents overnight, and my neighbors filled up their minivan last night on the 4th try after hitting three gas stations in a row that were out of gas.
I'll be riding my bicycle to work tomorrow. |
1977 / 930 (3.0L) / 302,000 on chassis / ~8K Mi on total engine rebuild/ 12 MPG hiway (5 MPG when dipping into the boost) / 91 octane (major $$ ouch, but I'm still going to hit 4 track days this month! ;) ) Can you say "addiction"?
Need some math help
My car has an odometer in miles, but here in Canada, our gas is in litres.
I have a stock 81' SC. How many gallons does it hold? I think I can get about 67 litres in the tank. |
79 SC - 13mpg around town, but it does really well on the highway, not sure of the numbers.
Re: Need some math help
1 imperial gallon=4.546L assuming a 17 gallon (US) tank, =64.345L |
Recently ran from Atlanta to Philadelphia...850 miles.
Used 31.5 gallons of gas or 27 MPG. This was also running the A/C for about 30% of the time. |
I have an 86' Carrera with 140,000 which gets about 17 aound town adn 28 on the road. If I drive 60-65 it does better. Coasting helps alot. I noticed a definate improvement with Synthetic Oil. Keep the air up on the tires, elimate the air conditioning, reducing weight and waxing the car also improves mileage. If you go to extreme you could use syn oil and grease and improve 5-10%.
It is hard to drive 65 when all of those Hundais and Geos want to go 80. Sometimes you just have to "turn it on" but you do pay the price when the mileage drops. |
I was wondering, since we are on the subject, how performance upgrades (exhaust, chip, higher compression, ignition, intake mods) affect mileage? There should be improvement in mileage if the engine can run leaner with higher octane gas. Also improved combustion efficiency and reduced friction should improve mileage.
Re: Re: Need some math help
it depends...
1979 SC coupe/3.0L stock/88K miles going around the track at redline: 9mpg driving back on the freeway after blowing all the carbon out: 21mpg |
Re: Re: Re: Need some math help
1985/ Carrera Targa/125,000/ 24 MPG
84 3.2
I just finished 2200 miles going up the California, Oregon and Washington Coast with my wife and light luggage. I checked the mileage almost every tank. The worst was 22 MPG and the best was almost 26 MPG. I was not driving real hard and was taking in the scenery most of the time but I did have my moments of excitement. I'm sure the Steve Wong chip and SSI's helped. |
Paul, How much did the chip help..what was your mileage before? I think it should be better because the chip reduces top end rich levels. Also did you do anything else to improve air flow?
stock 1967, 911S 9 in the city and 21 on the highway
DG624, sorry, I bought the car and immediately tore it apart and restored it. I only put 80 miles on it with the old parts. From the looks of the above posts, I guess I should be jumping for joy with the mileage I am getting. I do want to repeat that most of my driving was sight seeing up and down the coast.
Also, I know Steve bumps the timing up which really helps part throttle driving. I have been using mid grade gas. |
| All times are GMT -8. The time now is 04:43 AM. |
