Fanatic
backup & reverse lights dead
The car: my '87 coupe.
The problem: a few weeks back, reverse/backup lights only came on when handbrake was pulled UP. When brake lever was released (down), the backup lights would go out -- even though the car was engaged in reverse. NOW, the backup lights don't come on at all, and -- oddly -- neither do any of the brake lights -- neither the normal rears nor the rear windshield-mounted third brake light. Brake lights don't come on when I step on the brake pedal, either. Fuses check out OK. Could these two circuits be related somehow? Might there be a common connection or physical terminal somewhere to check? I highly doubt all the bulbs are simultaneously blown; there must be another related cause... Car has no other "symptoms" or other electrical problems. Any thoughts? Thanks, --Steve
1992 C2 Turbo coupe 1987 Carrera coupe 1986 944 (semi-retired in Phoenix) '57, '68, '70(x2), '72 Beetles (R.I.P.) |
Cigars and 911's -- Smile
Check the rear fuse relay in engine compartment. Lots of areas where they might have loosened and/or disconnected.
[GruppeB # 978] 1978 911 SC ROW (Pure Euro, no DOT or EPA work done..) 1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket) 2001 Audi - A6 Quattro 4.2L-V8 (love the growl) 2014 Honda Odyssey for the soccer-team/accessories |
