Spanner size for rear e height adjust.
Two part question
1) How much ride height range is there by loosening the torison bar plate bolt and eccentric bolt.
2) What is the size of the spanner I need to adjust the large eccentric bolt on the inside of the plate??
HB Kramer
(4 sneaks and 6 airheads): 79 911SC Coupe (sunroof delete)
(2 sneaks and 2 airheads): BMWS: R12GS(a) R90S, and some old British iron as well.
Old 09-26-2005, 09:21 AM
Formerly bb80sc
Vipergrün's Avatar
1. You should be able to get 1/2-3/4 either way adjusting the eccentric. This will raise/lower the car, but will upset the balance if has been set.
2. 36mm, go you your local bike shop and buy a thin 36mm head wrench
-B
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 09-26-2005, 10:04 AM
Thanks appreciated.
,as well as input on coner bal.
i doubt it has been set,so I will adjust with the eccentric first.
Maybe a corner balance for Christmas.after SSI and Chain Tensioner install
HB Kramer
Old 09-26-2005, 10:51 AM
