Idle Control Valve Troubleshooting
I have done may searches just need a quick answer. My car dose not stall but when I let my foot of the gas to come to a stop the rpm’s drop to 500 bounce to 1100 then settle to 850. Last night it tried the jump wire method. As soon as the wires made contact The rpm’s rose about 300 rpm’s I set the idle back to 850 with the idle adjustment 8mm. Revved the engine and the bounce was gone. Removed the jump wires rpm’s dropped 300 and bounce was back. I have cleaned the ICV, but I may need a replacement WHAT DO YOU THINK? |
I'm guessing it can't hurt. They're not too expensive. I replaced mine a while back.
In Porsche Dollars $180 aint bad!
GFCC
There is a resistance test you can do on them. I can't tell you the numbers (another pelican has my manual) but I'm sure someone will chime in.
Also when you cleaned it did you take it apart? If you did, did you get it oriented the way it was? If you didn't take it apart you may want to. This will ensure it is completely clean. Use isopropal alcohol.
Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current Last edited by Jeff; 09-27-2005 at 10:46 AM.. |
Besides, I can tell yours works because it's regulating the idle at 850 but it's having difficulty getting there since your basic settings are out of wack. Cheers, Joe Last edited by stlrj; 09-27-2005 at 02:36 PM.. |
Usually when that ICV goes bad your engine will begin to hunt radically, up and down, up and down, up and down etc.
When was the last time the O2 sensor was replaced?
The Fox Carrera |
The car got smoged two months ago, I don't think it has ever been replaced 50K on engine.
Any experienced mechanic could easily reset your idle, charge you $180 for an ISV that was never touched and send you off with a smile. For that matter, why not bring it to me in Novato and for $180 (I won't even charge you labor) I can garantee your idle will be perfect. Joe Last edited by stlrj; 09-28-2005 at 10:30 AM.. |
Took the car in it, was running rich. Made ajust. still a bit
of a bounce but not so bad, I was told a small bounce is normal? Now the car drops RPM's down to 600 bounces up to 1000 (insteed of 1100) and settles 850. |
Mine bounces with a/c on, doesn't when it's off. Its better with a Wong chip-one of the things the stock chip does is shut off fuel delivery above x rpm on closed throttle, which seems to contribute to the bounce. If the car doesn't stall, stop looking at the tach.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
Ya, but it hard they put the tachometer smack dab in the middle. Don’t even get me started on the little orange shift light!!!!!!!!!!!
You can take the annoying gas consumption shift light out of commission (and even just keep the rev reminder light).
Doug
1971 RSR - interpretation |
