Slippery Slope Victim
NY65912's Avatar
Lightbulb CHT testing question
I just tried to test my CHT on the '85 TL. I've had problems with a rich mixture.
The CHT only has 1 wire hence 1 pin. The connector from the DME has 2 pins.
I tried testing the resistance, ohm meter touching the 1 pin on the CHT and ground, I got a reading of 2.54 ohms, within spec I believe.
I thought I might test for continuity, same placement and there is no continuity. Should there be continuity?
Is the CHT good, bad or ugly?
Any help welcomed.
MikeČ
1985 M491
Old 09-29-2005, 04:30 PM
greglepore's Avatar
Not to be a wiseguy, but how can there be no continuity if there is resistance? If there is resistance anything other than infinity, there is by definition continuity.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 09-29-2005, 04:32 PM
NY65912's Avatar
My point exactly Greg.
MikeČ
1985 M491
Old 09-29-2005, 04:34 PM
it's the old style anyway, so yank it and install the newer two wire sensor. the one wire sensors cause various running and dying problems when they get old, which they all are now.
206 637 4071
Old 09-29-2005, 04:55 PM
NY65912's Avatar
Thanks John, I'll order one up now. What is with the 2 pin connector and single pin sensor though?
MikeČ
1985 M491
Old 09-29-2005, 05:16 PM
Large Registered Member
PatrickB's Avatar
So even if you happened to replace with a new OEM single wire CHT, it will suddenly not work either?
'85 Carrera Coupe, Marble Grey #118 JP/R6
'93 Lexus SC400, '00 Ford F-150
'70 911T- 2.7 (SOLD)
Old 09-29-2005, 05:49 PM
PatrickB's Avatar
let me be more specific!
a new OEM "style" single wire CHT....
Old 09-29-2005, 05:52 PM
there are none. all two wire now.
206 637 4071
Old 09-29-2005, 07:11 PM
