Slippery Slope Victim
I just tried to test my CHT on the '85 TL. I've had problems with a rich mixture.
The CHT only has 1 wire hence 1 pin. The connector from the DME has 2 pins. I tried testing the resistance, ohm meter touching the 1 pin on the CHT and ground, I got a reading of 2.54 ohms, within spec I believe. I thought I might test for continuity, same placement and there is no continuity. Should there be continuity? Is the CHT good, bad or ugly? Any help welcomed. Thanks
MikeČ 1985 M491 |
Not to be a wiseguy, but how can there be no continuity if there is resistance? If there is resistance anything other than infinity, there is by definition continuity.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
My point exactly Greg.
MikeČ 1985 M491 |
it's the old style anyway, so yank it and install the newer two wire sensor. the one wire sensors cause various running and dying problems when they get old, which they all are now.
Thanks John, I'll order one up now. What is with the 2 pin connector and single pin sensor though?
MikeČ 1985 M491 |
Large Registered Member
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) |
let me be more specific!
a new OEM "style" single wire CHT....
there are none. all two wire now.
