kdubb's Avatar
Question Please HELP!!
I have a 1985 911. When I drive it, the stering wheel shakes left to right vigorously. What could be the problem (bushings)?
Old 10-02-2005, 07:42 PM
scottb's Avatar
Is there play in the steering column when the car isn't moving? If so, the nylon bushing in the column may have disintergrated. Pelican sells a replacement that's very easy to install.
1984 Targa
Old 10-02-2005, 08:44 PM
kdubb's Avatar
Question
Thanks for the info. It does not seem to have a lot of play, but I will double check. Are their any other suggestions?
Old 10-02-2005, 08:46 PM
Kantry Member
oldE's Avatar
I would check for: damage to the tire (broken belts, etc.), damaged rim, lost wheel weights, loose tie-rod end, loose wheel nuts.
Les
Best
Les
Old 10-03-2005, 02:56 AM
