Fuchs 8" vs 9" question
Just wondering from those who have gone froms 8s to 9s in the rear.
I can barely tell the difference visually, if at all, between the two, but is there any noticible difference in "stickiness," especially on the track? Assuming the same tires and size, is there a considerable improvement, or is it more subtle? Thanks in advance, all!
Edward
993: retired Trackmeister, now daily driver heaven
911SC: resident Trackmeister-in-progress
Old 10-05-2005, 11:42 AM
stv951's Avatar
I 've done that, and you are right. There is not much visual difference. Tire wise, my 8s had 225s whereas 9s have 245s
Old 10-05-2005, 11:46 AM
stv951's Avatar
Any detailed pics of both ?
Here are some 9x16
[img]
http://forums.pelicanparts.com/uploads6/fuchs+9x16+new1128539426.jpg[/img]
Old 10-05-2005, 12:14 PM
I'd have to agree, its the 245 of the rear that helps. Unless your going to go with a 225 up front ( with a 8"951 rim) then a better balance might be the 205-225 set up with 7's and 8's.
Old 10-05-2005, 12:15 PM
KobaltBlau's Avatar
What? you don't need 9s to run 245s.
Andy
Old 10-05-2005, 12:25 PM
KobaltBlau's Avatar
How? For the Toyo RA-1 DOT R tire I like to run in 245/45-16 the recommended wheel width is 8".
I know the racer's argument about sidewalls being more stretched out and that being somehow better but I think the tire manufacturer's recommendation is good enough for me.
Andy
Old 10-05-2005, 12:38 PM
Thanks for the input, all ...keep it coming.
But I have run 245s on my 8s with no squirreliness whatsoever. In fact, it feels really planted on the track (w/205s on 7s), and this with street tires, not r-compounds. Agreed that 9s would be better for 245s, which is why I asked the question in the first place. But if you look at 245s on 8s, there is no bulging, and the sidewalls "seem" pretty well supported. I was just wondering that given the same 245, is there a marked improvement with the 9? Thanks!
Edward
Old 10-05-2005, 01:06 PM
Bill Verburg's Avatar
Once again the measuring rim has been mistaken for the recommended rim. Toyo has a recommended range of rim sizes. for the 245/45 x16 RA-1 comp radial this is 7.5" - 9", what they don't tell you is that max performance from a given tire will almost always be obtained by using the widest wheel in the recommended range. This last tidbit is a fact not a fairy tale
Bill Verburg
Old 10-05-2005, 01:20 PM
KobaltBlau's Avatar
OK Bill, I was not aware of this (obviously). Can you characterize the difference in performance between a 245/45-16 DOT R tire on an 8" rim versus the same tire on a 9" rim? Thanks in advance.
Andy
Old 10-05-2005, 01:26 PM
stv951's Avatar
Abit OT, but should I add 14mm spacers on the rears ? Would widening the track decrease oversteer ?
Old 10-05-2005, 01:28 PM
The wheel has geater leverage on the tire carcass, the sidewalls are effectively stiffer, the tread squirms less, the tire runs cooler and at lower slip angles. These are all good things from a performance perspective.
The bad side(to some) is that the ride is harsher.
there have been many back to back timed tests of this concept
Bill Verburg
Old 10-05-2005, 01:31 PM
Administrator
Jack Olsen's Avatar
Nines are obviously better. But how much better, in practice, is a valid question. I've driven both, and the differences weren't noticable at all to me. In a race between a car with 245's on 8's and one with 245's on 9's, it'd likely be other factors that would make one car faster than the other.
Old 10-05-2005, 01:32 PM
stv951's Avatar
Thanks Bill,
should I increase stud sizes for these 15mm spacers ? or they will have enough threads to be safe ?
Old 10-05-2005, 01:34 PM
KobaltBlau's Avatar
OK, what you say makes sense.
Where? or what do I search for. very interested.
Thanks,
Andy
Old 10-05-2005, 01:35 PM
petrolblue83911's Avatar
Doesn't it also seem that it depends on the tire mfg?
-I had 255's on the rear of my 928s4 on cup alloys (9 or 9.5 wide) with AVS sports, and i swear they looked narrower than my previous 245's which had been dunlop sp8000's on the stock phone dials, it was more of a visual thing, but really, they looked narrower than the smaller tires??
Old 10-05-2005, 01:38 PM
wider rear track will increase oversteer
Bill Verburg
Old 10-05-2005, 01:40 PM
Thanks,
I think that Grassroiots my have done one recently. Some of the tire manufacturers have published this info, Michelin for sure.
Bill Verburg
Old 10-05-2005, 01:42 PM
KobaltBlau's Avatar
ok, I will try to find those. thanks again, Bill.
Andy
Old 10-05-2005, 01:44 PM
One other small factor should be noted, If you have a limited slip and you go with 245's they will really grab out of the tight stuff, especially when get on it early, which will make the car want to go in a straight line not good on the street. I have 7 x 16's and 8 x 16's with 225 50's with my 60% ZF, I tried 245 and it flet like a swamp buggie with the front wheels in the air cranked the in opposite direction
Old 10-05-2005, 02:08 PM
