Originally posted by SoCal911SC
Here's a 9. Like above, you need them if you want/have to run 245s.
And here's an 8, with a 225.
(BTW, the 9s on the black car were done by Weidman. The 8s on the red car were done by Al Reed).
Can we see more than just the wheel.
Old 10-05-2005, 02:24 PM
Bill Verburg's Avatar
If you have a limited slip and you go with 245's they will really grab out of the tight stuff, especially when get on it early, which will make the car want to go in a straight line not good on the street. I have 7 x 16's and 8 x 16's with 225 50's with my 60% ZF
A lsd will mak any set up under steer more, the higher the lockup % the more effect it has, thats why, for a mostly street driven car 40% is as high as I would want.
An even better setup is a split 40/60 lsd
Bill Verburg
Old 10-05-2005, 02:29 PM
Your right, when the trans was apart I had it set up at 60% thinking I would do more track time but it turns out It's alot more steet time. I can only imagin what the early turbo drivers felt when the got on it out of a short freeway sweeper....anybody still out there who can comment on the 75/76 turbo with LSD... not the 4-way/windowpane
Old 10-05-2005, 02:44 PM
The factory used a 7 inch/205 and 9 inch/245 set up, seems to work fine.
For a Turbo. These are significantly heavier in the rear the a narrow body car that most are changing to. Still works but I like more rubber up front to match the 245.
Old 10-05-2005, 04:10 PM
Originally posted by Jack Olsen
Nines are obviously better. But how much better, in practice, is a valid question. I've driven both, and the differences weren't noticable at all to me. In a race between a car with 245's on 8's and one with 245's on 9's, it'd likely be other factors that would make one car faster than the other.
Ahhh, that's what I was looking for ..an opinion based on having tried it. Thanks, Jack!
Thanks for all the chiming in. Obviously I'd *like* to have 9s for the aforementioned advantages, but if there's no significant *felt* benefit (at my skill level, anyhow), then I'll stop dreaming and budget for other goodies. Thanks, all!
Edward
993: retired Trackmeister, now daily driver heaven
911SC: resident Trackmeister-in-progress
Old 10-05-2005, 05:01 PM
Ahhhh ..... Bill V... do you want to rethink your answer about wider rear track will increase oversteer?
You are the admitted Grand Master on brakes and wheels.....but think this one through once more....
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 10-07-2005, 03:09 AM
Yes, I meant to say wider rear track will increase understeer
Bill Verburg
Old 10-07-2005, 03:42 AM
jaydubya's Avatar
If you're gonna run 8s and 9s, why wouldn't you just use 225 and 255 tires?
'82 911SC racecar
'05 WRX STi
Old 10-07-2005, 06:14 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Depends on which wheel diameter you're talking about.
16's are not readily available in a 255 section width that's the appropriate size. The most common size is 255/50 which is an inch taller than appropriate. More common rear sizes are 245/45 and 245/50. The 245/45 is the right size for our application. Front choices for 225 front are 225/50 or 225/45. The 45's are usually the better choice to avoid clearance problems (shorter OD), but not as readily available as the 225/50
17's are plentiful in 225 and 255 section widths. Typical sizes are 225/45 front and 255/40 rear. Or 235/40 front and 255/40 rear, 275/40 rear. Or 245/45 front and 275/40 rear. As you can see, the choices for 17's are much broader.
Kevin L
'86 Carrera "Larry"
Old 10-07-2005, 06:47 AM
Kevin it right on. IMHO the perfect wheel tire setup for a 911 narrow body is 225/45/16 on 8" 951 offsets front and 245/45/16 on 9" turbo rims rear. (of course this is what I run, so I'm biased )
Old 10-07-2005, 07:56 AM
stv951's Avatar
89911 : I'd love to see the 8s at the front. Pics please - PICS !!!
Old 10-07-2005, 08:29 AM
Here's a thread that shows 951 8's on the front of 911s:
Need help with my 951 Fuchs
-Scott
Old 10-07-2005, 08:42 AM
jaydubya's Avatar
You didn't say Fuchs so
'82 911SC racecar
'05 WRX STi
Old 10-07-2005, 08:43 AM
Old 10-07-2005, 08:46 AM
Just to add to Kevin's and 89911's comments
Unless you regear the transmission you will want to stay close to the factory design height for the tires which is ~25" &#177
Doesn't matter whether the wheels are 16, 17 or 18", when the tire height or more specifically the loaded rolling radius(which is generally not published) is increased, bag things happen to the overall gearing and percieved performance of the car.
There are good reasons to go to taller tires for a specific track, but not for overall general use.
Bill Verburg
Old 10-07-2005, 09:23 AM
