aj88cab's Avatar
Cross Drilled rotors - clogged holes?
Before my last DE I was bleeding the brakes and found this on my left-front rotor. The holes were clogged (see pic). It was easy to just stick a wire in them and clean them out, but I was wondering if anybody has had this problem, and what might be the cause.
And now for the confession...I had left the Hawk Blue pads on the car for 2 months since my last DE and did about 1k miles of street driving with them. I'm guessing that is not a good thing to do.
Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 12-16-2004, 07:05 AM
Plavan's Avatar
I have never had any holes clog on our rotors. Maybe its time to change to a different brake pad. We all use Ferodo pads in our race cars. They are cheap and offer very good feel and braking. They are also easy on the rotors.
Some guys swear to use Pagid $$$$. We all think they are a waste of money and kill your rotors. If I can lock up my brakes at the begining of a race and at the end of the race, my pads are working
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 12-16-2004, 07:57 AM
Crossed drilled rotors, when done correctly, have a chamfer of about of 45 degrees. When the rotor wears, it can loose this chamfer and the holes are now at 90 degrees. The holes then act as a cutting edge and will remove material from the pad, sometimes clogging the holes. Were both rotors clogged, or just the one? By the picture, your rotors look fairly new. Did you buy them drilled, or have them drilled after purchase?
www.exeterautosupply.com
1976 911S Targa
Old 12-16-2004, 08:06 AM
Automotive Monomaniac
Emission's Avatar
My rotors collect a tiny bit of dust/pad material in the holes, but nothing near what you are experiencing! I'd try different pads as something isn't adding up.
Here is a pic of my rotor "dirty" (without me punching the crud out of the drilled holes).
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 12-16-2004, 08:25 AM
aj88cab's Avatar
I installed the rotors new in May. I rebuilt all the calipers at that time also. The rotors were purchased cross drilled. They have 3 DE's, 2 "spirited" mountain runs, and about 2k miles of street driving (1k with the Hawk Blues) on them. Only this left-front rotor had the problem. I didn't notice any additional clogging after the DE last month. I have the street pads (OEM) installed now and am keeping an eye on it.
The fact that it only happened on one side concerns me. There is no pulling, the car stops straight as an arrow.
Andrew
Old 12-16-2004, 08:42 AM
Emission's Avatar
Do you think it could be the rotation?
In my pic, the rotor turns clockwise. In your pic, it appears the rotor turns counterclockwise - this is the opposite of how Porsche "directionalizes" their drilled rotors. Are both of your rotors identical (so one turns one direction, the other the opposite)? Mine are different, therefore they have specific sides.
Old 12-16-2004, 08:49 AM
ewave's Avatar
My rotors were very clogged on both a 930 and a 911 with turbo style rotors- Front AND rear. Very hard driving, - Used a set of pads in one wheekend. I just used a 1/8 inch punch to clean them out...
Paul
2001 CLK55 AMG, 1987 911 Turbo Look, 1997 Viper GTS.
Old 12-16-2004, 08:54 AM
Sounds like a friction material issue to me. I would do what you said and keep an eye on the OE pads.
1976 911S Targa
Old 12-16-2004, 08:55 AM
aj88cab's Avatar
Interesting point. These are Zimmerman rotors and the "direction" of the holes is the same. They do not make a left and right side rotor as far as I know. So, yes, the holes "turn" in different directions. I noticed this when I purchaced them and found a post about it here as well. There didn't seem to be any concern expressed in the postings. But.....
Old 12-16-2004, 08:58 AM
Emission's Avatar
I can't understand how it would make ANY difference, but since you are getting buildup on only that side...
Old 12-16-2004, 09:02 AM
aj88cab's Avatar
I wouldn't think so either, but it is the only obvious difference from side to side. I'll kep an eye on things and see what happens.
Anybody have any specific experience with Hawk pads and rotor wear?
Thanks for all the input guys.
Andrew
Old 12-16-2004, 09:46 AM
Grady Clay's Avatar
Is there anything restricting the air flow thru the internal rotor vents? Inspect the openings toward the spindle.
Everyone, note the shadow of the pad on the rotor surface.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 12-16-2004, 11:04 AM
aj88cab's Avatar
I will check for clear air flow, but I'm pretty sure there was no obstruction at the internal vents. Good idea though!
The shadow on the rotor was there after I cleaned the assembly with break cleaner before working on it. What you see is the residue from where the pad was contacting the rotor. It's just dried brake dust and it wiped clean.
Andrew
Old 12-16-2004, 11:26 AM
my 2c,
I'm using the Zimmerman rotors, and had the clogging issue after one DE event while using Mintex brake pads, switched to Hawk no clogging after 4 DE events
carrue529
1987 911 Carrera
S.Wong chip|ElginCams|GT3 oil pump|short gearing|Guard TB-Diff|22/29 Hollow T-Bars|monobloc calipers|Bilstein HD/Sport|Turbo tie rods|Strut brace|CobraMonza II seats|7, 9 Fuchs|Elephant polybronze bearings F/R|Wevo eng mounts|bypass cat pipe|M&K muffler
Old 12-16-2004, 12:13 PM
Bill Verburg's Avatar
They can clog but most people clean w/ water or air often enough that its not an issue.
The pictured 911 rotors have an internal structure which doesn't move as much air at speed as the 930 rotors which are factory drilled(Actually cast but das macht nichts)
Some pads do generate far more dust and detrius than others
Bill Verburg
Old 12-16-2004, 03:00 PM
aj88cab's Avatar
Bill, are you saying I need to bathe more often?
Andrew
Old 12-16-2004, 03:18 PM
Fuchs w h o r e
An interesting theory I used to believe. After inspecting the rotors on my friend's collection of motorcycles, it doesn't seem to concern the manufacturers. Honda, Yamaha and Suzuki all have absolutely no chamfer on any holes, just a sharp edge.
Old 12-16-2004, 05:00 PM
Chris Lovell's Avatar
Bill,
"clean with w/ water or air"? Maybe I am just dated (that's an understatement) but aren't we supposed to keep shop air away from brakes as a safety practice? If asbestos and other problems are history, I would like to use air to clear these clogs and help with other brake work.
Thanks for any clarification.
CWL
'88 Carrera Cab
Old 11-15-2007, 12:01 PM
aj88cab's Avatar
Always a surprize to see an old thread pop up again....
Update - I do not use cross-drilled rotors anymore. The front rotors developed cracks, I replaced them, then the rears started to crack. I switched to Powerslot rotors back in April. I still use the Hawk Blue pads. The x-drilled rotors with new pads were great for the first DE then they would develop "saturn rings" that would wear the pads into a "wavey" surface, with clogged holes, and heavy rotor wear that resulted in a ridge on the edge of the rotor. The braking would degrade after a DE or two, and end up fading pretty bad, and the cracking is inevitable. I was getting about 2 DEs out of the front pads and about 3 on the rears. Some of the pads would wear at an angle. All this after I installed some cooling ducts too.
The Powerslot rotors and Hawk Blue pads currently installed have run 4 DE's, the braking is still as good as day one, the pads are wearing evenly front to back, no angled pad wear, nothing to clog, and very little rotor wear with no rings or ridges after the 4 DEs. I still run the factory calipers, on a typically overweight Carrera Cab. The pads are about done, but I could get another day out of them if I needed, but they will go in the "spares" box...safety first!
I have a set of slightly used (one DE) front x-drilled rotors I will make anyone a good deal on
My previous rotor woes:
Are my X-Drilled rotors toast (small cracks)?
Odd place for a rotor crack
Andrew
Old 11-15-2007, 01:37 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Might want to consider a different pad, even though your problems have been solved with the PowerSlot rotors and Hawk Blue combination.
Hawk Blues are known for being harsh on rotors. For the same price you could use PF97 Performance Friction pads and experience not nearly the rotor wear, with exceptional braking performance- very fade resistant.
I'd stick with the stock undrilled Zimmermans in lieu of the PowerSlots. I believe I recall the Porsche PowerSlots are slotted OEM rotors. So there's nothing a whole lot better about them other than the nice plating and slots- maybe some additional balancing. The OEM Zimmerman rotors are certainly up to the task of track use.
Kevin L
'86 Carrera "Larry"
Old 11-15-2007, 02:02 PM
