1985 rear parcel/shelf screws
I have a 1985-911, looking for the four (4) screws that hold the rear parcel shelf in place-unable to find it on the host site-any help would be appreciated--the photo is copied from another site. Thanks
I think they are just black, oval-head sheet metal screws with black finishing washers. You can probably find them at McMaster, although someone needs to provide the correct screw diameter. You could grab a selection of zinc screws at Home Depot to test fit for size, then buy the black ones.
Mark
1979 911SC Targa |
911 carrera 3.2 (1985)
I think...
90014504107 tapping screw 3,5x16 99959111707 cone washer Kees
parcel shelf screws
69 porsche
Yes the stock size screws are 1 1/2 x 6, with cup washers in matt black counter sunk , half raised head, photo of one of mine, Note the cup washers can slide on and off ,not like most modern ones available at parts stores, and also the original cup washers are smaller then modern ones. |
Wayne-Thanks for the photo and confirming the size-Gordon
From how I read the PET, the bottom screws are M3.5 x 22 and the top are M3.5 x 16. Looks like the top screws are used to secure the seat straps only. A 1 1/2 inch long screw is quite a bit longer!
Would love someone to provide the definitive answer as I'm planning to finally fix my rear seats this Spring and would like to use the correct hardware. |
Vintage Owner
The top screws just fasten the strap, no need to remove.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Resurrecting this thread. Did anyone ever find the correct screw sizes for the parcel deck?
'87 Targa
Several correct posts above. What specific year are you searching?
For 87-89 there are only 2 (top ones were eliminated): 900 145 072 07 Tapping screw B 3,5 X 22 Unless you have automatic 3-point seat belt (opt M335) 900 145 008 07 Tapping screw B 3,5 X 32 |
