Replacing the Engine Compartment Sound Mat
Has anyone done this before? After the recent rain we've had in the Northeast, the adhesive gave way and now mostly sags. Tried the 3M Adhesive but it doesn't work given that the foam rubber backing is in poor shape. I thought I should replace it but am not sure exactly how. Any thoughts?
I did mine with the motor out. It would be tough to do with it in place, IMO. I used the high temp 3M contact cement, and it worked well. This, of course, was after spending a fair amount of time getting the old adhesive off. Again, the motor was out.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Used Up User
It is can be done motor in. Remove everything you can, clean (as well as you can until your patience runs out) & jam it into place dry. Then fold down - leaving the bottom jammed in & just glue just the horizontal area. I used 2 adhesives. A trim/rubber gasket glue & the 3M spray as a contact to hold it in place while the glue cured.
And it's not going anywhere. If or when I drop, I'll glue the vertical part. Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
Thanks. Yeah - getting all the old foam off looks like a NIGHTMARE and gluing it deep in the the back of the compartment seems nearly impossible. I don't think it's worth dropping the engine just to put in a new pad. Does the padding serve any other purpose other than to dampen the noise (e.g. heat)?
You'll find that a few people have left them off to save weight. Not sure how much louder it is. Mine's freakin' loud with the headers and muffler already, so I can't imagine it being a whole lot worse.
Alii&Maui
Just did mine. Went to Home Depot (do a search on their web site)and bought foil backed insulation. It came in a roll 16"X25' and paid $13.00. It also comes in a 24"X25' roll. I used two pieces instead of one big one which I think was easier to maneuver into place and glue down.
I wish I could take credit on this idea but someone else thought of it. As far as weight, I think the whole roll weighs a pound. Another thing is if you have speakers they won't get heat soaked like mine did.
1982 SC Coupe SCWDP#0087 KCSSL#0082 |
Used Up User
I rode for most of the summer without one & then installed it in August. I was surprised at how much noise it did cut down. And I have a Cab. My first thought was that it wasn't as nice as without . . . but it is more spouse friendly.
Ian
Used Up User
Stock (Pelican) sound pad:
Stop laughing & pointing at my disgusting fan. Ian
Good looking job jesset100.. Were you at the Autumn Derby this year? I think we met. Dan
I have plenty of lead for my pencil... just not enough paper to write on.. 82SC with 95 993 engine 2004 Ford Powerstroke |
