VFR750's Avatar
Replace Grommet after A/C Removal with solid plug?
I'm getting ready to pull the A/C from my 82SC. I have looked at a drawing that says there is a rubber grommet that seals the line running from the rear condenser to the front condenser, to the chassis. Porsche part number 901.573.143.00.
Once the line is removed there will be a hole in the grommet. And a hole in the chassis.
Is there a proper Porsche grommet, without a hole in it, (aka, a "plug") to seal the chassis?
I imagine the hole may have existed in cars prior to the factory making A/C standard, but I can't find any reference to a chassis plug.
Mike
'82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar.
Old 11-03-2005, 03:45 PM
Bird. It's the word...
Fishcop's Avatar
I just went to a local place that specializes in rubber extrusions. They had hundreds of various rubber plugs and grommets... You should plug them to keep "things" out.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 11-03-2005, 06:20 PM
